1995 C280 electrical problem
Old Jul 31, 2006 | 11:03 PM
Kevinc2's Avatar
i have a 1995 C280 for some reason all the gauge on the intrustment dash sometime it work and sometime it not any one have any idea? and also the turn signal , wiper and hazard switch...etc aren't working neither i search around and found that some people state that maybe the relay is bad and where is the relay located anyone know.....??? hope to heard respond from you guy thanks alot.
Old Aug 2, 2006 | 08:21 AM
shandy2550's Avatar
1995 c220 auto
First check all your fuses in the large fusebox in the engine compartment, it is unlikely that your turn signal and wiper problem is due to the relay being faulty as it is a module with a bank of relays inside for the separate systems , more likely that fuses have blown.
Can you describe in more detail what the problem is with your gauges in the instrument panel.
Geo.
Old Aug 2, 2006 | 11:32 PM
Kevinc2's Avatar
well about the gauge the rmp gauge,temp gauge and fuel gauge aren't moving it just stay at one point but the speed gauge is working but when the speed gauge is not working then the other 3 not working also if i recycle the key 1 or 2 time then it working normal , that's all i see at this point ,any suggest??
Old Aug 3, 2006 | 09:01 AM
shandy2550's Avatar
1995 c220 auto
All I can think of about your gauges is that you have a poor contact at the plugs on the back of the instrument panel or the earth lead for the panel.
Geo
