Turn off Check Engine Light
Old Dec 19, 2009 | 08:30 PM
wammer23's Avatar
1995 S420 Black/Gray
If I buy a code scanner and turn the Check Engine Light off, will it come back on immediately if I don't fix the issue that caused it?
Thanks,
Wes
Old Dec 20, 2009 | 01:01 AM
99MBSport's Avatar
1999 C280 Sport
If it doesn't return after going 125 or so miles it probably will store the problem code. Chances are ..yes it will return but not right away
Old Dec 23, 2009 | 07:58 PM
maksi's Avatar
2020 GLC200 (X253) 1995 mb W202 C220, 2008 Mitsubishi Lancer Evolution, 2014 Ford Mustang 5.0
Thanks,
Wes
dude,
you need to address the problem right away. in my case, i had to use a starcom (the PC that connects to your car) and had the fault erased. there is a reason why the check engine light came on your dash.
just my two cent worth.
