both turn signal and hazardlight won't work
Old Jan 28, 2010 | 02:37 PM
renato's Avatar
94-MBC-220/03-ML320
Hello there, my problem start after my battery went dead for not using the benz.coz, during winter time i don't use the benz.so the battery went dead. now i removed the battery from the car and charge it. for 8- hours. now after charging it i install the battery and start the car. everything works except when i left turn and use the left turn signal is not working i turn on the right not working either, i try to press the hazard warning light its not working either.anybody has an idea,why this happenned. i did not checked the fuse yet. coz, today here in chicago the temp, is 5-degress to zero degress, and the windchill is 10 below zero. i don't want my hand to frossbite.please if anybody experience this let me know. thanks.
Old Jan 28, 2010 | 05:04 PM
AcousticplayerJ's Avatar
2000 c230 Kompressor
I'd check the fusebox. Sounds very very likely that your problem lies within that. Perhaps your battery was overcharged somehow and had just enough extra current to blow the fuse. There might be a diagram in your fuse box saying which fuse goes to those lights. Bundle up!
Old Feb 2, 2010 | 08:16 AM
thtguy's Avatar
2017 GLS 550
Check Defroster and Intermittent wiper settings. If those are not working either then it is more than likely the combination Relay that controls Turn/Hazard/Defrost/Intermittent wipers.
Old Feb 23, 2010 | 02:42 PM
renato's Avatar
94-MBC-220/03-ML320
thanks. guys i will check the fuse then i will check the combination relay that controls the turn/hazard/ defrost/and intermittent wippers.thanks a lot.
Old Oct 7, 2011 | 11:23 AM
eunan709's Avatar
c200
hi i have the same problem with my 97 C200 where is this combination relay
Old Oct 7, 2011 | 02:26 PM
Sniper73's Avatar
W202 C280
Hi,
the contact ring between steering wheel and fixation of the steering wheel can also be response for that item that no turning signal works.
regards
