1998 C230 power window circuit board
Old Jun 24, 2012 | 06:14 PM
ptcruiser's Avatar
C230
Today, I pulled the console and removed the power window buttons unit.
How do you actually open the case holding the buttons to check the printed circuit???
When I turn it over, there are REALLY small torx screws that seem to hold the plastic case together. Do those have to be removed to get at the circuit board?
Old Jun 25, 2012 | 12:14 PM
taz069's Avatar
chevrolet z-71
On my 96 c280 their is slide clips on each side. Once they are moved the complete board and all switches pop right out. Also check into club 202. It's mainly a club for w202 owners and their is a ton of info their.
Old Jun 25, 2012 | 02:27 PM
ptcruiser's Avatar
C230
I saw that slide, and it didn't appear it could be removed. I gave it a good once over to see where a clip may be to remove it from the frame with the buttons, but nothing jumped out at me.
Regards
Old Jun 25, 2012 | 05:53 PM
taz069's Avatar
chevrolet z-71
As i mentioned mine is a 96. Just pulled mine again and on mine you can see on the side of either slide the notch's front and back it just has to be pushed in the opposite direction. Mine also has a lip that is toward the park position on each tab, to help with the moving of the slide. As i mentioned mine is a 96 c280. Hope it works. The first time i did mine it was a stubborn lil bugger.
