W210 Power Folding + Blinker Mirrors on W202 need help
Alright,
So I have the option of purchasing the one mod I've been dying to source and install on my w202. It is the power folding and blinker mirrors off of w210. Problem is that I found them from the UK. Which means that the auto-dimming feature after installation will be on my passenger side mirror!!! First of all I want to know if I should buy them. Second I would like to know what else besides the mirrors and the switch I'll need to retro-fit. And third is how to wire it (wiring diagram would be helpful) and how to switch the auto-dimming feature to be on the correct side. I'm in the US, so LHD!!! Thanks in advance :) |
100% Agree with you, It's one of great mod. for W202,,
prefer if you can go to the junkyard and took the wiring from W210, i done that for my W202..:) ZAYED,, |
The Folding aspect of the mirror adds quite a bit of complexity. This is in addition to that the RHD LHD issue. Some manufacturers (can't speak to Mercedes)have the mirror housings at slightly different angles for LHD and RHD models so please check that out. Adding the W210 blinking only mirros is relatively straight forward and inexpensive to souce parts stateside on ebay. As much as the folding feature is really slick and cool, the incremental cost in parts and labor involved is huge.
I gave up on the one from the UK. Looking into options from Germany though :) if there's a link thread on DIY Install that you could reply with, would be greatly appreciated :)
Originally Posted by cm60k
(Post 6298754)
prefer if you can go to the junkyard and took the wiring from W210, done that for my W202..:) ZAYED,, |
Was so simple bro.,
i took the mirrors with harness from 01-02 "W210", match the colors of the wiring harness with W202,, 96-02 "W202/W208/W210", sharing the same mirrors wiring harness colors..:) -;ZAYED;- |
(Post 7524981)
Was so simple bro,o
With Elc. power folding mirrors..
-;ZAYED;- |
(Post 7525041)
-;ZAYED;- |
Ah, Sorry, forgot to tell; depend to the door harness spec.,
mine comes with additional (8-pin), with additional two unused pins for blinkers, code "B/MM2",, i matched the harness connectors from 01-02 "W210", then connect the L/R wires directly from unused pin (# 6) to door control module. -;ZAYED;- |
(Post 7525069)
mine comes with additional (8-pin), with additional two unused pins for blinkers, code "B/MM2",, i matched the harness connectors from 01-02 "W210", then connect the L/R wires directly from unused pin (# 6) to door control module. -;ZAYED;- This looks like its going to be a little headache because none of the DIY really match the other DIY informationn, If I get my hand on everything I will write up a DIY |
It's not that hard bro., matter of soldering wires,
seems, my setup is differ than yours,, if so, you can simply use 01-02 "W210" mirrors harness/connectors, and match the colors,, then get additional wires directly to front blinkers..:) -;ZAYED;- |
(Post 7525488)
seems, my setup is differ than yours,, if so, you can simply use 01-02 "W210" mirrors harness/connectors, and match the colors,, then get additional wires directly to front blinkers..:) -;ZAYED;- How do you control your mirrors? |
I thought you already have folding mirrors..!,,
honestly; this is the first time i heard 98-00 C43 without folding system..!!,, maybe U.S version comes as optional..!?! -;ZAYED;- |
(Post 7525548)
honestly; this is the first time i heard 98-00 C43 without folding system..!!,, maybe U.S version comes as optional..!?! -;ZAYED;- I hope that the harness are the same:) |
