speedometer says 55 but actual vehicle speed is 65
Old Mar 17, 2015 | 05:15 AM
lightninwillie's Avatar
'97 C280; '12 C250
How do I reset or adjust to proper reading.
Old Mar 17, 2015 | 05:37 AM
cm60k's Avatar
Did you replace the cluster recently..?, do you have this issue later..??, does someone open or work out in your cluster before..???
ZAYED,,
Old Mar 17, 2015 | 03:23 PM
'97 C280; '12 C250
I had cluster repaired, yes.
Old Mar 17, 2015 | 07:09 PM
cm60k's Avatar
I think when they remove & return back the mph/km needle, they not adjusted well, cause it should be adjusted manually,,
mostly; this issue happen after recombine clusters..!!
ZAYED,,
