wobble bolts
a friend recently told me about wobble bolts.. just wondering if anyone on here uses them? looking to convert from 5x112 stud pattern to 5x114.3. has anyone on here done this? i drive a c280 w202 95. thanks
What your looking for is an adapter. When looking on the internet, be sure to include/check the "bore" of the original wheel, you will need this! As the spacing is so close to the original stud pattern, it may be hard to find.
Originally Posted by ptcruiser
(Post 6489121)
What do you mean by an adaptor? |
Are you using stock wheels..?
ZAYED,, |
Originally Posted by cm60k
(Post 6489879)
ZAYED,, |
1 Attachment(s)
That means you need wobble bolts with cone seat(see pic.),,
Attachment 312684 but you have to measure the bolt hole from that 114.3 wheels, is it for M12 bolts or M14 bolts..? ZAYED,, |
(Post 6489888)
I've used them before, but don't track my car or drive like a nut. if you get the proper sizing you should be fine for a street application.
Originally Posted by CorradoJr
(Post 6490010)
