How much volt should it be to camshaft sensor?
mercedes c220 c36
Im having trouble with my c36 amg 1996 with the m104 Engine.
Im getting fault code reading: Camshaft sensor: not recognize or implausible
I have concluded that it beginned with the wiring was shorted out so the signal cable was touching the negative feed but i have switched that but it still the same problem.
Is there anyone that know what the input voltage should be from the ecu to the camshaft sensor so i know if the ecu still working?
I have also tried with a different camshaft sensor though i put it in before i got to change the wiring. can i have destroyed the both camshaft sensors?
can i test the camshaft sensor somehow and if that possible how do i do it?
