Codes P0300, P0301, & P0303 etc... HELP!!!
Old 10-18-2018, 04:51 PM
vegastud's Avatar
kompressor, c230
I have a 2000 c230 Kompressor (W202). It has 175,000 miles.
I was passing a car yesterday and gave it some gas to get by and the check Engine light came on. It drove very rough and badly after the Check Engine light came on. I got it home and checked the codes. There was one code, P0301.
I did a compression check:
Cylinder 1 psi: 160 & 155
Cylinder 2 psi: 130 & 135
Cylinder 3 psi: 160 & 160
Cylinder 4 psi: 120 & 120
I then installed new spark plugs and spark plug wires (I had bought some a month back, hadn’t installed them yet).
I then changed the places of the two coils. I put #1 & #2 coil where coil #3 & #4 was, and vice versa.
Now I have five new Check Engine codes: P0300, P0301, P0303, P0300 P, & P0301 P.
Anyone have any advice or answers. Thanks in advance.
Vegas
Old 10-18-2018, 05:55 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Have you checked your MAF?
What about your cats? any rattling noises when you start the car?
Old 10-21-2018, 01:20 AM
vegastud's Avatar
kompressor, c230
So an update.
When I swapped the coil packs it triggered more Check Engine codes. My guess was the coils were bad. I bought two new coil packs from Autohausaz, installed them and my C230 is running well again. Problem solved.
Thanks for everyone that responded
Old 12-16-2018, 08:00 PM
ontariobill's Avatar
1999 C280
I had the same problem with my C280, I didn't swap coils but found the misfire on #4 and replaced the coil, worked like a charm no further issues
Quick Reply: Codes P0300, P0301, & P0303 etc... HELP!!!
