C280 V6 to I6 swap
Old Feb 28, 2022 | 08:22 PM
Sabadara's Avatar
2007 CLK550
C280 V6 to I6 swap
Contemplating V6 (M112) to I6 (M104) swap on a 1999 C280. My main question is whether the V6 transmission will fit the I6 engine. In case it does fit, is there going to be a problem coupling a V6 TCU with a I6 ECU? I'm assuming V6 ECU will not run I6. And is there anything else that's going to be problematic with this swap? Thanks in advance.
Old Oct 3, 2023 | 09:55 PM
rob8's Avatar
2003 CLK320
Did you ever make the swap, and if so how did it go? These forums are very scarce on responses, as I have found out. Benzworld is a better bet to actually get a response.
Rob
