W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
Old Apr 2, 2009 | 10:52 PM
  #1151
benze-ply's Avatar
'05 C230Kss
H&R springs with Koni Yellow Adjustables
here is my suspension set-up:
Model: 2005 Mercedes C230
Springs: H&R Springs cut half a coil in the front (I think half, not sure exactly )
Rear Pad: #4
Shocks: Koni Yellow Adjustables
Wheels: SL500/SL600 - 18x8.5 Fronts 18x9.5 Rear
Tires: Falken 452 - 225/40/18 Fronts 255/35/18 Rear
Front is like 1/3 inch gap and rear is about 3/4 inch gap.
Old Apr 3, 2009 | 02:20 AM
  #1152
rocafel1a's Avatar
05.C230K.SS
Rear Pad: #4
sorry for being a noob, but what do the spring pads do? whats the difference between #1, #2, so on../.
Old Apr 3, 2009 | 02:24 AM
  #1153
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
damn, Yen, the car looks awesome!
Old Apr 3, 2009 | 07:23 AM
  #1154
Glyn M Ruck's Avatar
Super Moderator
That is one neat machine!
Old Apr 3, 2009 | 12:09 PM
  #1155
ebargados's Avatar
2002 c230 coupe
Originally Posted by kirax2
umm ummm umm actually is the hardest..
perhaps your statement is true when the damper setting is set to 1 but completely false when it's set to 9.
obviously you haven' t ridden in one set in the softest setting. mine are set to 9 and just slightly stiffer than stock.
Old Apr 12, 2009 | 11:54 PM
  #1156
Markizzy's Avatar
C230
i was thinking for the H&R coilovers do they all have the same part number for the w203s coz im thinking of getting a used one which came off from a c230k coupe i have a c230k sedan...need ur help guys
Old Apr 13, 2009 | 03:41 AM
  #1157
Mu9enx's Avatar
01' C32o
markizzy,
it'll fit
Old May 13, 2009 | 04:49 AM
  #1158
W203E35's Avatar
2006 C350 Sport 6MT
Tire rub due to shock problem?
Hey guys,
So I was driving on the freeway when I got some tire rub. Even with the spacers I was getting rub only on the rear left. So I was just looking and my rear left is about a full inch lower than my rear right. I can fit 2 fingers on all 3 (front and rear right) but on the rear left I can barely fit one finger
What will this be from and also will the warranty cover this?
P.S Maybe I can add the spacer and have them flushed like before since the right never rubbed
Right now the rears dont have spacers.
Old May 13, 2009 | 04:38 PM
  #1159
Super Moderator
Have you done any mods to the rear suspension? Are the correct thickness perch pads in place? - have you replaced shocks recently?
Your problem can be caused by stiction on the back shocks - (tight seals & wipers on the shaft which causes stick/slip motion) This can also be caused by a shock that has failed on the rebound action only & is trying to extend itself.
All this presumes you don't have a soft spring.
Old May 13, 2009 | 04:41 PM
  #1160
ChaRgeC230's Avatar
05 c230 SS
same thing with mines. my passenger side front and rear sits lower than the driver side. i cant figure out why. this is on stock springs and shocks with 19's
Old May 13, 2009 | 04:44 PM
  #1161
W203E35's Avatar
2006 C350 Sport 6MT
I haven't done anything to the rear suspension. It's the sport suspension (MB). When I press the trunk/rear fender down to test the shock it does move/wobble more than the right side.
Old May 13, 2009 | 04:49 PM
  #1162
W203E35's Avatar
2006 C350 Sport 6MT
That's exactly what my setup is except my rear left only is lower. I know the rims didn't cause this because when I got them on I was getting tire rub only rear left. So the Lorinser shop took off the spacers and it was minimal only on high speeds (freeway).
So I checked to see why one side would hit the tire and that's when I noticed it.
Although I have noticed the w203 is a lot stiffer than the w204. Maybe the suspension is too stiff and something goes wrong? So they learned from their mistakes from the w203 and made the w204 softer?
Basically I believe this isn't from the rims. This happened before I put the rims.
Off topic I fit ET38 on the rear of the w203 without spacers with no problems.
Old May 13, 2009 | 10:40 PM
  #1163
W203E35's Avatar
2006 C350 Sport 6MT
WTF i'm going crazy here guys. I was going to ask a coworker who owns a C320 Wagon about my issue and the rear left was FINE. I couldn't believe it, it was perfectly fine. Then once I got home I checked again and it was messed up again.
I dont get it does this mean my shock is messed up. After driving it goes down and after being parked for hours it comes back up???
Anyone hear something like this?
These Benzes have a mind of their own.
Old May 16, 2009 | 11:55 PM
  #1164
rocafel1a's Avatar
05.C230K.SS
Help!
Is it possible to run 235/35/19 up front with wheels et35 and coilovers without getting spacers? if i need spacers, would 5mm work or 10mm?
Old May 17, 2009 | 12:55 AM
  #1165
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
Originally Posted by rocafel1a
Help!
Depending on how low you want to go, I'm pretty sure with that setup you'll need at least a 5mm spacer...
Old May 17, 2009 | 12:28 PM
  #1166
rocafel1a's Avatar
05.C230K.SS
thanks Roland. what about h&r springs? they probably would clear the brakes and the coils?
Old May 17, 2009 | 05:33 PM
  #1167
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
springs = coils. when you only do springs the clearance issue is only with the struts, not the spring perch and/or coils on the coilovers.
brakes clearance has nothing to do with how low your car is.
Old May 18, 2009 | 02:43 AM
  #1168
rocafel1a's Avatar
05.C230K.SS
cuz i talked with mjbenz and anthuny, they said that they didnt need spacers with their h&r sport springs and 19" wheels. just wanting to make sure
Old May 18, 2009 | 02:48 AM
  #1169
ROLLNNN's Avatar
if your just doing H&R springs then you don't have to worry about clearance, you'll be fine with 235/35. If you are still getting the MRR GT1, the +35 should clear your brakes, i believe that's the offset everyone gets with those - you might want to double check with someone who has them though. Are you still getting those?
This might help, but definitely not necessary: I'm not sure what type of sizing MRR does, but a 19x8 instead of 8.5 will make fitment with coilovers and if you need/want spacers a whole lot easier, just my opinion...
Old May 18, 2009 | 02:58 AM
  #1170
ROLLNNN's Avatar
If you are going with lowering springs(not coilovers) you wont need spacers unless your wheel does not clear the brake. If you get wheels that are made to clear the brakes(correct offset & face) then you wont need spacers....
Old May 18, 2009 | 03:12 AM
  #1171
rocafel1a's Avatar
05.C230K.SS
thanks again Roland. I'm actually going to make a trip down to the wheel supply and ask them for fitment and stuff. they quoted me 2250 for wheel/tire package, h&r springs, alignment, balance, installation. i think thats pretty good price, but i already ordered my falkens elsewhere
TWS was actually real nice cuz i told them that I could get the springs for 240 online, and they said, "dont bother waiting we can match that price!" so it made me want them to do order them through TWS.
i dont remember if I talked with Albert or some other guy though...
Old May 18, 2009 | 05:31 AM
  #1172
Mu9enx's Avatar
01' C32o
Most likely Albert; he's that dude!
Old May 19, 2009 | 06:52 AM
  #1173
mobwers's Avatar
none
Thanks for that info,
So, I don't need spacers anymore.
Old Jul 10, 2009 | 10:31 PM
  #1174
jayton41's Avatar
05 C55 & 06 C230 SS
K-sport coil overs !!!!!
hey guys i was doing sum research and i found these
they are coil overs and usually coilovers are to soft for track use but look at this video
http://www.youtube.com/watch?v=-A2vEOgKkoQ
these coil overs look hard enough for auto-x wat do u guys think????
Old Jul 10, 2009 | 11:16 PM
  #1175
skittles's Avatar
Moped
saw those C/O a million times on ebay.. i dont think its worth it. i dont remember where i heard this but someone told me before that someone was using those on the track and they flew off.. also those dont look right for the mercedes.. id say stick to the H&R and koni yellows.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
