Factory CD-Changer MY03
It makes little difference to me. I have the Audio 10
. And Yes, it does sound that much better than the stock stereo.-Eric
So, for me, this is good news. I can get the changer I wanted for a much more digestable charge. Not worth buying an Audio 10 or anything else in my mind.
Best regards,
CP
So, the days of $1000 changers are quickly coming to an end. In fact, even the press release has some info for the dealers to calm their fears about not being able to make $1000 per changer.
Why don't they dip into the parts bin and find a multi-disc indash CD changer like many cars have. 3 or 4 disc would be nice.
Do you know if the changer is in-dash or glove box mount?
I don't expect Autoclass.net to lower their retail price, either, as their net margin is already very low. ...RAB
i have ordered changer from autoclass.net
should i cancel and wait till the price drop??
hm....
So, in my opinion, I think you will be able to pick one up for basically the same $400 that one built with the car will cost.
Best regards,
CP
"If a service part is $400, dealer cost is probably closer to about $340."
I am not sure if that is necessarily true in the case of stereos. We do know that the current changer costs the dealer approx $500 which they mark up to $800 to $1000. So, if the same percentages play out for the new changer, the cost is probably closer to $200 than $340. Also, when one can buy a CD changer at BestBuy for $120 to $170, there is a limit to what even MBUSA can charge their dealers.
The press release does seem to address those points. Again, I doubt a changer added to a 2002, for example, will cost you anything greater than $400 to $500. My local dealer offered to put in a changer from MB that I was going to buy from eBay for $70. So, even if they charge full retail ($400) plus installation, we are still under $500. That I can handle.
Best regards,
CP
I'm a former M-B employee and therefore, I know whereof I speak.
The variable here has always been the installation cost. CD changers used to be $595 retail and dealer cost was a little over $500. The $800 and $1,000 figures come about when the dealer adds "installation charges" to that. Believe it or not, there is not very much markup in parts on the dealer's end of things.
Also, MB can charge dealers whatever they want for parts and accessories and the dealer is SOL. The S-class brochures cost the dealer $5 each. That big yellow "C" sign you see in showrooms was almost $500 and every dealer was forced to purchase one.
MB is the one who is getting rich. The dealer is trying to make it up by gouging people for installs.
CP,
To top it all off, the exact same Alpine changer with AI-net instead of D2B costs $199.99 installed at a couple of the big box electronics stores nearby.
My dealer wanted $595 plus $150 for install - which is not bad. I think its a $750 option if you have it "factory" installed. (They do it at port, actually). I'd have to look again.
Good luck to you either way. If you get stuck during an install, many folks here can help you out, including me.
I got the Audio 10 CD and the CD Changer. It sounds so good in my coupe that someone with a C320 and 10 speaker Bose though it sound better than his.
Cost on the MY2003 Cd changer is $348 according the a recent factory listing.
Our cars arent pre-wired with the fibre/power looms to the trunk, and retrofitting those is a nightmare ..
Of course. the C class glovebox install is easy to retrofit those looms.
I imagine that next year MB USA will stop having the CD changer as dealer fit (by not pre-installing that part of the fibre loom), it will be factory or nothing. Then the dealers can charge $1000 in labour to install on cars without factory fit :-)
BTW. same is true for phones here, they are all Nokia and all factory fitted.And they are a pain to retrofit [with the exception of the ML that has some of the wiring pre-installed, but I guess thats because its built in the US]
Having used both cartridge type and in-dash single CD's, I much prefer the cartridge units... Load it up in the morning. Play it all day. No need to change discs, a big safety issue with me. Access to the changer in the trunk area would not be good, but access in the glove box is just fine.
IMHO, the Audio 10 is still a superior head unit for overall sound. Plus the convenience of playing a CD without a cartridge cannot be overlooked.
The Audio 10 CD rocks!
