View Poll Results: How many of you have used Dyno Mode on your Car to Have some Fun (Burn Outs, Fish tai
Yes
57
46.72%
No
65
53.28%
Voters: 122. You may not vote on this poll
Dyno Mode - All you want to know
Old 08-18-2003, 01:07 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Question Dyno Mode - All you want to know
What happened?
(-EDIT - added by drexappeal 9/7/07)
For 2003+ models, I just found out how to get this working every single time without fail (since I had problems with my battery recently):
1) put key in ignition
2) turn key to position 1
3) toggle menu to overall mileage screen
4) turn key to off position
5) turn key back to position 1
6) press odometer reset button 3 times quickly
7) screen automatically shows battery voltage
8) toggle through pages using steering wheel control until it gets to dynomometer page
9) use +/- buttons to choose ON
10) Turn ignition on and car will be in dyno mode at that point. You will know for sure when the display toggles through ESP/ABS/BAS screens.
*If menu is already set to display overall mileage screen, you can skip steps 4 and 5.
**Overall mileage does NOT have to be set to zero for this to work.
To turn it off dyno mode, you have to go back to the menu screen and de-select ON.
Old 08-18-2003, 02:07 PM
revstriker's Avatar
K Car
I'm not sure which thread you are talking about, but there are still numerous threads that have instructions on how to use the dyno mode. Do a search for "enable dyno mode".
Old 08-18-2003, 02:37 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
The one I'm talking about is for 03 and up c-class that I posted. All the older ones don't apply to the newer ones. Ask MB-BOB, because he tried the new versus old instructions. One of the mods had turned it into a sticky as well. It was there yesterday and after today's MBWorld crash it is gone.
Old 08-19-2003, 08:50 AM
RED320's Avatar
C320 W203 02, Command, xenon, sun roof, avantgarde, phone nokia, sport seats, sport suspension, rain
What has happened with post 'Hooray 03 Dyno mode info'?
Where is this?
Old 08-19-2003, 03:49 PM
moomeh
Guest
Posts: n/a
yup, no more sticky. that is weird.
Old 08-19-2003, 11:38 PM
breastroker's Avatar
2003 C230 K , 2001 ML320
I have all the Dyno mode instructions with photos in both Word and PDF format. Anyone wanting it let me know.
Old 08-20-2003, 06:17 AM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Thanx for saving it. You got mail.
Old 08-26-2003, 10:35 PM
I sent the 232K PDF file to Buellwinkle to post on his web site for all to download. Check out:http://www.buellwinkle.com/
Under "how to's" or direct to the pdf
http://members.***.net/buellwinkle/dynomode2003.pdf
Old 08-27-2003, 12:09 AM
Admin Alumni
MB-BOB's Avatar
See Garage
This is a puzzling issue. I did a search and could not find this thread.
I did not un-stick it, nor did Revstriker (I presume by his post). I wonder if someone posted to it during the forum downtime last week, and it got lost in the shuffle when a couple day's worth of files were lost.
Old 08-27-2003, 01:54 AM
Lynn's Avatar
It was gone before the down time, Bob.
Old 08-27-2003, 10:56 AM
electromethod's Avatar
Honda Grom
i also noticed that a lot of my buddy list dissappeared all the sudden a few days after I had added them. is the problem resolved?
Old 01-22-2004, 02:49 PM
04c230ksedan's Avatar
I ran a search yesterday on getting my car into dyno mode so
that I can check where my oil levels are. I tried, and tried and
tried but couldn't get the car into dyno mode...I searched a little
more today and it seems that 03's and above can't go into dyno
mode.. is this correct?
Old 01-22-2004, 04:12 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
It works. Just click the link provided and read it carefully.
Old 01-22-2004, 04:27 PM
Lynn's Avatar
Maybe they changed it again for the 2004's.
Old 01-22-2004, 05:39 PM
thanks.. I'm going to give it another try tonight. grrr I h8te not being able to follow simple instructions
Old 01-22-2004, 06:37 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Nope. Tried it on an 04 at the stealership during my service A visit and it worked. Does it surprise anyone that new showroom cars are already a quart low based on the dyno mode? :p
Old 01-27-2004, 01:24 AM
SUNILP's Avatar
2015 E250D
Dyno Mode not working
I did the steps as described and it does not work at all. I get in the car, close door, put key in pos 1, hold reset down forever. Never beeps. Am I doing something wrong?
Old 01-27-2004, 01:46 AM
Lynn's Avatar
MB changed the procedure for the 2003's. Try this
Old 02-08-2004, 04:19 PM
czachari's Avatar
2003 C230
Dyno mode weirdness
I get into dyno mode ok but for Oil Levl. I get -.-
For engine: I get ------------------------------.
If I start the engine while in Dyno mode, I get
Oil Levl 4.4 qts and it slowly goes fown to 3.8qts
the Engine: shows M271 and some other numbers.
Why can't I see the oil level when the engine is off?
Is 4.4 qts too low?
CZ
Old 02-08-2004, 11:16 PM
levelr123g's Avatar
you need to turn the ignition to on to see the reading. DO NOT start the car and your numbers should show up.
Old 02-23-2004, 10:11 PM
SUNILP's Avatar
2015 E250D
Dyno Mode Help
I have searched the forum for the dyno mode and tried it several times. I put key in IGn, pos 1, hold reset down for several minutes and no luck. I have tired pos 2 even. Door closed and door open also. What gives?
Old 02-23-2004, 10:46 PM
moomeh
Guest
Posts: n/a
might be overlooked, but did you make sure you are on the odometer screen?
Old 02-24-2004, 06:24 AM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
From you description I say you are using the wrong code to access the dyno mode. You are using the MY02 instead of the MY03. In your case you have to press the reset button 3 times in quick succession instead of holding it down while waiting.
Old 07-22-2004, 08:58 AM
ketan's Avatar
2004.5 C320 Sports Sedan
How Many Have Usex Dyno Mode?
How many of you have used Dyno Mode on your Car to Have some Fun (Burn Outs, Fish tails, etc...)?
ketan's Avatar
How Many Have Used Dyno Mode?
Quick Reply: Dyno Mode - All you want to know
