Alignment Recommendations?
Old Sep 14, 2005 | 08:25 PM
gen13's Avatar
My 2001 C240 has only 22k on the tires. Biut the outside edge of both front wheels are totally worn. I rotated the wheel every 5K and all 4 wheels are worn on the outside. I need an alignment.
Could someone recommend a place that can do mercedes alignment besides the dealership. I live in the Bay Area. thanks
Old Sep 14, 2005 | 08:31 PM
Brunelleschi's Avatar
In the market
i haven't found a place other than the dealership that is even willing to try....and i have looked.....most places look at the car and then turn away...of course in oklahoma benz's are uncommon and more intimidating than in bay area
Old Sep 14, 2005 | 08:48 PM
mig888's Avatar
EVE
Auto Innovations, Milpitas CA. 408-956-8004.
Go there, ask for Orlando. Tell him Jose referred you to that excellent place (he aligned me with the camber arms on the "blue" merc - tell him that!). You have to watch how he works it's unbelievable . You'll like the Hunter alignment machine I gaurantee it.
He's done 4 mercs, all C-classes, but then again, all with rear adjustable camber arms.
flip
I hope you have camber arms and bolts. Makes his job tons easier and with better adjustability to return to spec (if you've lowered the car).
Old Sep 15, 2005 | 12:06 AM
Blake P's Avatar
'09 A4 S Line
flip
What are camber arms?
Old Sep 15, 2005 | 01:01 AM
mleskovar's Avatar
'17 Jaguar XF
Sounds like you are an agressive driver....it's unlikely (but but possible) that all 4 corners need alignment. What's your driving environment?
Old Sep 15, 2005 | 01:35 AM
gen13's Avatar
What I meant was the front set does most of the wear. As I rotate the tires from back to front, the "new" front tires gets worn. Thus after 4 rotations (rotate every 5K miles), all 4 tires are all worn on the outside edge. I know it's the front wheel that's very much mis-align and caused excessive wear on the tires. My wife drives the car mostly so I know the car is not driven agressively at all.
Thanks mig888 for the recommendation. Anyone else had good alignment experience in the Bay Area?
Old Sep 15, 2005 | 02:24 AM
mig888's Avatar
EVE
Pay attention to your tire pressure as well. I'm considering raising mine to 40+ PSI all around to maximize center tire wear. Go to autoinnovations!
flip
Old Sep 15, 2005 | 02:37 AM
phattbam's Avatar
'08 BMW e92 335i
flip
correction.. he's done mine too. but I'm one without the camber arms....
