Problem With 6Disc Changer
Old Oct 26, 2005 | 03:58 PM
swale's Avatar
C220 CDI
Hi,
Have a stock mercedes cd changer and have found that when I use copied disc it seems to skip at certain points throughout the disc is this normal is there anything that can be done to stop this?
(uk c200 CDI 2005 stock cd changer factory fitted to car)
Thanks!!
Old Oct 26, 2005 | 05:05 PM
raymond g-'s Avatar
99 E320
am encountering similar with my Audio 10, though not yet with the changer.
am experimenting with different laser strength settings, buffer settings,
write speeds, as well as silent gap spacings etc trying to isolate the cause
for this problem.
Old Oct 27, 2005 | 02:24 PM
ninjanick's Avatar
Happens to me too. 2005 C230K. The single CD player in the dash doesn't seem to suffer from this problem ... only the 6-dsic changer in the glove. I've had a similar problem occur with my 99 ML320 6-disc, but that was diagnosed as "failed laser".
Old Oct 27, 2005 | 02:56 PM
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
burn it at a lower speed like 3x or 6x
Old Oct 27, 2005 | 03:13 PM
slvrstar's Avatar
clk
Mine seems to be okay.
Old Oct 27, 2005 | 03:24 PM
royboy's Avatar
2002 ML320, 2000 E320 wagon far from stock
we've found benz changers don't like burned discs or even foreign cd's. Here's a bit from a bulletin:
32/01-2 Group 82.64 - ALL MODELS, USE OF NON COMMERCIAL COMPACT DISCS IN MBUSA CD CHANGERS AND CD PLAYERS: Programmable Compact Discs such as CD-R and CD-RW may not play back correctly in MBUSA CD Players. For complaints related to playback of CD-R and CD-RW audio CD's in MBUSA CD Players, verify correct operation of CD Player with a Commercial Compact Disc. Due to variations in CD-R and CD-RW media and technical inconsistencies in programming a CD-R or CD-RW Compact Disc, MBUSA does not support their use in MBUSA CD Players. Do not replace any parts for this issue.
'05 and later comands that play mp3's haven't had too many problems over this
Old Oct 28, 2005 | 02:03 AM
white_w203's Avatar
is SOLD
the cd changer in the glove box sucks. i burn cd's and sometimes it reads the cd and sometimes it doesn't and sometimes it takes a long time to just read the cd. the stereo in the dash reads the burned cd all the time.
Old Oct 28, 2005 | 08:35 AM
MB-BOB's Avatar
Admin Alumni
See Garage
I have three cassettes either in the CD player or stored to the side. Two of them are full of burned CDs and they play without skipping flawlessly... AFTER I burned them at slower speeds. I use 16X today, rather than 24X. Garbage in = garbage out.
Old Oct 28, 2005 | 09:47 AM
tyro's Avatar
BANNED
Mine skips from time to time and lets out one of those screech-glitch noises
Old Oct 28, 2005 | 10:45 AM
StillKickin's Avatar
Mine 2005 C230 Kompressor, Dad's 2005 ML350
I have the same problem but I find myself using the dash CD more than the changer anyway, the dash CD is less picky...is there any way to make the stock system play MP3 cds?
Old Nov 26, 2005 | 06:10 AM
Ada's Avatar
Ada
When people say they have burned a CD at a slower speed and they have found better results, it's always a CD media issue. Depending on what CD media you have bought (Fujifilm, Memorex, Maxell, etc), your results on a successful burn will vary. These huge companies do not make their own CD-Rs, but buy them from companies like Ritek, CMC Magnetics, Taiyo Yuden, etc and brand their logo on top of the CD-R to call it theirs.
I've run plenty of disc quality scans and diagnostics then compared them after my burn with different media and noticed a few things. I can burn Taiyo Yudens at 40x without any C2 errors or disc quality errors. Better media == flawless faster burns. I cannot burn CMC Magnetics at 40x or I will result in C2 erros and plenty of bad sectors, so I must burn this media at 24x max.
I have had my run-in with all sorts of media and the best ones that I have burned have been the Taiyo Yuden brand. Probably the easiest place to get Taiyo Yudens are from Best Buy. Look for the Fujifilm spindle that has been made in Japan and not Taiwan. I believe the ones made in Taiwan are from CMC Magenetics and those are pretty low quality.
Anyways, just to give relevance to my post, I have burnt CD-Rs on both Taiyo Yudens (Fujifilms) and CMC Magentics (Memorex) and even with both flawless discs, I still get pauses/cutouts during playback on my changer. I still have yet to buy Ritek CD-Rs and give them a whirl, but when I do, I'll be sure to post an update.
I would recommend visiting the link below and testing out one of your burnt CD-Rs to identify what kind of CD-R brand you have. Because if you're like me and love high quality burning, you will figure out what brand you have so you don't burn too fast and have a resulting crackling audio near the end of the CD or during bad sector burns.
http://www.cdrlabs.com/kprobe/index.php
Old Nov 26, 2005 | 03:47 PM
Ru4Rl's Avatar
I have 2004 C230K with changer in glove compartment. I've listened to both CDs I burned myself and ones bought at street fairs that were 'homebrewed'. Haven't had a problem yet with any of them. I burn off a Mac if that makes any difference and use Sony CD-Rs.
Old Nov 26, 2005 | 04:00 PM
advans's Avatar
C55 ///AMG, 535xi
I agree, burn it at a slower speed
Old Nov 26, 2005 | 04:03 PM
white_w203's Avatar
is SOLD
some people actually want the crappy cd changer. i've seen it on ebay go for $200.
