Sprint Booster - Car behaving like a monster and hungry for speed
Old Mar 29, 2007 | 02:49 AM
  #376
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
Are They Really Good!?! Omfg Should I Get One???
Old Mar 29, 2007 | 03:30 AM
  #377
tommy's Avatar
2004 Civic Si. FWD for the Win!
Originally Posted by C230 Sport Coup
I keep thinking of the Audi 5000, and how it supposedly accelerated by itself....if anyone recalls...
Yes, "sudden unintended acceleration", later proved to be 100% driver error, as people were hitting the gas pedal instead of the brake. 60 Minutes lost a lot of credibility on that one.
I've got same basic mods as you do. I'm very happy with it. It's the initial "wtf - where's the power?" lag that I've always had in my car that now is not there. If you could fully depress the gas pedal immediately, it would do the same thing; obviously, you can't, so that's not really a valid alternative.
Old Mar 29, 2007 | 08:33 AM
  #378
eunosracr's Avatar
2006 C230 Sedan
I just ordered one yesterday. Does anyone have any install tips?
Old Mar 29, 2007 | 09:04 AM
  #379
tommy's Avatar
Go through this entire thread, and read all referenced parallel threads. Once you read every one, you'll realize how easy the install is.
Old Mar 29, 2007 | 10:54 AM
  #380
eunosracr's Avatar
2006 C230 Sedan
Will do. Thanx !
Old Mar 29, 2007 | 11:58 AM
  #381
Midnight Koop's Avatar
CL203
Originally Posted by BadAssC230k
I heard rumors that there is an SB for auto and manual. I tried going to slk's site and emailed him, but no response.
i heard the auto sb and manual sb are two different as far as aggressiveness. there was a rumor going around that you could put the manual sb on the auto and it would be more aggressive then the auto sb on auto. any of this true?
if thats the case, then im all about the manual sb on auto.
its not a rumor... its true. a bunch of us ordered from cks performance on the group buy page... and i think they're still taking late orders if you want one (manual or auto).
Old Mar 29, 2007 | 12:42 PM
  #382
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
Thats what I'm running, it works well. The car will adjust and get a little easier to drive. You get used to it and the car adjust a little. Then on those evel days you can do a throttle reset and go like heck.
Old Mar 30, 2007 | 09:47 AM
  #383
PhilC230's Avatar
Never got my Booster either from SLK
I bought mine exactly 1 month ago and have not heard a thing since.
SLK...If you're out there, please email me to let me know things are cool and I'll fix the PayPal problem.
I emailed you like 8 times since I bought the Booster and have heard absolutely nothing from you in a month now.
Please let me know what the deal is...its been a long time now....If you are just on vacation or something then Im cool with that....just email me to let me know what's up.
Old Mar 31, 2007 | 08:47 PM
  #384
jinijazz's Avatar
Boxster987 C230KSS M3
Installation Instructions
What I hated from our "sport" sedan was the below-average shifter and horrible throttle lag. Seriously considering to sell. Not anymore! Installed SB today, and it delivers what it promised. The better throttle response. Way better! This is THE mode we are waiting for!
BTW, who said it's 15mins job??? Putting back the pedal assembly can take the whole day! Seriously, here is the complete installation instructions(I put together forum members' advices scattered across the forum) and just add mine for reassemling step which can make your life a lot easier.
1A. Remove the platic cap with flat bed screw driver (pic 1)
1B. Remove the 10mm bolt nut & washer(pic 1)
2. OK, before you remove the pedal assembly, look at this picture 2 carefully. Remember which tab is inside and which is outside. Especally number 2, I will talk about this tab later. (pic 2)
3. Remove the rubish plastic panel below the dashboard. Just unscrwew five T15 bolts and poped it out. (You do not have to remove it completely). We make it loose so that we can move the pedal assembly easily. Unless you want to see the insalltion meterial visible after installtion(as seen from some pics in this thread), do not skip this step.
4. Now remove the depal assembly, push upward -> rotate -> pull out. (pic 3)
5. Disconnect the connector. As Tommy described before, one side is "flat" surfaced and the other is rounded. Just match each side when you connect SB in between. See the pic. (pic 4 & pic 5)
6. Now put back the pedal assembly. As some some said before, "There is a square notch that the top of the pedal assy. has to go into. If the wire gets stuck in there it doesn't install correctly." If you did step 3, you can easily take care of both problems. Put your hand inside to guide while you puting back the assembly in. Without step 3, this can take forever. Now you put back the 10mm bolt nut & washer and tighten it.
7. Now adjust the rubber plastic panel(step3), so that the tabs I mentioned(step2) positioned correctly. Put the five T15 bolts back.
8. That's it. Now time to have some fun!
Attached Thumbnails Sprint Booster - Car behaving like a monster and hungry for speed-1-copy.jpg   Sprint Booster - Car behaving like a monster and hungry for speed-2-copy.jpg   Sprint Booster - Car behaving like a monster and hungry for speed-3-copy.jpg   Sprint Booster - Car behaving like a monster and hungry for speed-4-copy.jpg   Sprint Booster - Car behaving like a monster and hungry for speed-5-copy.jpg
Old Mar 31, 2007 | 09:09 PM
  #385
flush's Avatar
2003 C32
or you can use the brute force method and with enough tries, the whole thing magically slips in and sticks!
Old Mar 31, 2007 | 10:33 PM
  #386
ctC230K's Avatar
excites your girlfriend
wow jinijazz great installation DIY! drex u gotta add this post to the DIY section under Sprint Booster!
Old Mar 31, 2007 | 11:28 PM
  #387
eunosracr's Avatar
2006 C230 Sedan
Yeah no joke. I came across this tonight in preparation for my Sprint Booster install next week. Very clear and methodical. Thanks a ton !
CT i just noticed your sig says modified airbox. What exactly did you do to it if I may ask?
Old Apr 1, 2007 | 03:30 AM
  #388
ctC230K's Avatar
i shaved the honeycomb pattern off the airbox cover. some people on the forum thought it might increase the airflow but i never noticed any difference.
Old Apr 1, 2007 | 10:18 AM
  #389
eunosracr's Avatar
2006 C230 Sedan
Interesting. Thanks.
Old Apr 3, 2007 | 01:12 AM
  #390
jinijazz's Avatar
Thanks for kind words guys.
Last several days, I fell in love again with my 05 230K SS thanks to SB, I highly recommend to anyone who believe ours are "SPORT" sedan/coupe. C class is truly beatiful car in and out, it really deserves better throttle response (and the better shifter )
Thanks ctC230K and everyone who answered all my questions previously!
You are responsible for my speeding tickets
Old Apr 3, 2007 | 01:25 AM
  #391
ctC230K's Avatar
haha no problem, glad u like it!
Old Apr 3, 2007 | 02:20 AM
  #392
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
You guys are starting to **** me off...Oh I love my sprint booster Wooo!!!
I want to know what's inside this thing.
Can't someone be just a tiny bit technical?
How many pins is it?
Analyze the basic funtionality of the gas pedal?
A potentiometer? Rheostat? Digital or analog?
Resistance range before, and after SB?
Anyone out there know how to work a freakin' ohm meter?
C'mon, isn't there someone out there CURIOUS enough to determine
just WTF this thing is? I'm betting it's just a resistor.
a $250 resistor.
Whats it going to take to get someone to give some serious feedback, instead
OOOOooo I LOVE my Sprint Booster!!!
Frickin' make me puke.
East Esotonian crap.
Actually turns out it's made in Greece.
Perfect. And the price is going up.
Time to uh...(I hate to say it BUTT....) bend over and pay 300 for $1 in electronic components?
Sweet.
Where's Buell when you need him.
Man, developing the M111 pulley, those were the days.
Y'all have gone soft.
Old Apr 3, 2007 | 02:35 AM
  #393
BTW, one of the best write ups I've seen in a while.
Thanks for taking the time.
Old Apr 3, 2007 | 06:58 AM
  #394
tommy's Avatar
a $250 resistor.
Stop being a whiney pantywaste then, buy one yourself, and do a full analysis. Sheesh! 300 bucks ain't gonna kill you.
Old Apr 3, 2007 | 04:10 PM
  #395
Actually, it might...kill me.
I just got laid off, and I still need to paint the new rear bumper sitting in my closet. Thats got priority.
I'm just surprised at the lack of curiosity.
We'd all be spending 1-2 grand for a pulley if somone hadn't been curious and
didn't feel like spending 1-2 grand for something that shouldn't cost anywhere near that.
Old Apr 3, 2007 | 04:15 PM
  #396
eunosracr's Avatar
2006 C230 Sedan
Well I just got my SB today. It's sitting on my desk and I can't wait to install it. I'm tempted to cut out of work early bwahahaha.
Old Apr 3, 2007 | 07:20 PM
  #397
eunosracr's Avatar
2006 C230 Sedan
Wow I just installed my SB. What a difference. I wish I would have done this first. The car just jumps now. Its a bit scary really. Install was a piece of cake. Follow the instructions posted above as I did and you will be golden. Talk to you guys later Im going for a drive. SI Ecu + SB= Big smile.
Old Apr 3, 2007 | 07:23 PM
  #398
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
I have a 2002 SL500 that has been supercharged by HPS and has Speed Innovation custom ECU tuning.
Will sprint booster work in my car? If so, where and how can I purchase it?
Thanks in advance for any info.
Old Apr 3, 2007 | 08:27 PM
  #399
eunosracr's Avatar
2006 C230 Sedan
Email cks performance. I can only imagine what the SB will do for your car. I would get it in a heart beat if i were you.
Old Apr 4, 2007 | 06:52 PM
  #400
Tech-Tune's Avatar
After speeking to Stamatis over the phone this morning, I was convinced I wanted to buy this mod. I placed my order with him and should receive it in a few weeks. I'll post my opinions here for anyone interested.
Wish me luck
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
