What is factory torque setting on pulley?
C230K Brilliant Silver with C2, C7 and Bose system with 6-Disc Changer
Hi, Fellows.
I am planning to get an ASP pulley and install it myself.
Does anybody know the factory torque setting on pulley?
Is there difference of torque setting between factory & ASP Pulley?
Thank you in advance.
Kleemann posted 220 ft-lbs before. Seems kinda high. Check with the dealer. I don't have a torque wrench so I did it by the seat of my pants. Hasn't fallen off yet.
220ft/lbs sounds about right. Remember this is one big bolt holding on a large hunk of metal spinning at high speeds. There are at least 6 flywheel bolts and they are tightened to 100ft/lbs.
Re: What is factory torque setting on pulley?
Originally posted by hudkang3
Hi, Fellows.
Hi, Fellows.
picture: ASP pulley
Got mine yesterday... here's a picture of the pulley, a belt - 560K6 (this designation means: 56" length, 6 grooves) and a hockey puck for size comparison (Canadians don't understand inches, so here! )
Still in search for the exact setting torque for the pulley bolt.
I learned something very interesting on a saturday morning car shows this weekend. Torque for a bolt is a spec that depends on a certain lube specification. They torqued a bolt with the proper assembly lube and it had the right down force of about 130,000 lbs. but they used ordinary oil and torque it to the same spec and it was at about 98,000 lbs.. way below spec. So if you are going to go the whole 9 yards and torque it properly, make sure you lube the bolt with assembly lube and the washer side that faces the bolt head and not both sides of the washer to get it correct. You may already know this but it was news to me.
Also, after you get the factory spec, ask Lee to see if there are any adjustments you need to make for an alloy pulley vs. a steel one. It may be that 220 lbs. is too much force, I don't know.
I am ordering ASP Billet Pulley tommorow!!!!!!!!!
Hey ,
Thanks for replys guys.
Vadim , are you gonna do it yourself or have someone do it for you?
Will you post the process and the result?
I am planning on odering tommorow and installing it myself.
Hope that it is not gonna be too hard.
Good luck with the new pulley Vadim.
2008 VW GTI
Re: I am ordering ASP Billet Pulley tommorow!!!!!!!!!
Hey ,
Hey ,
http://www.rollinghillsfyi.com/BilletPulleyInstall.pdf
And thanks!
haha...yes...im alive...the benz....haha...that car is back totally stock now....sad....but true....
he got the engine rebuilt and everything running....tried a custom turbo setup on it....ran a 13.5....the stock clutch went to pieces!
he then got all that tuned out but was having some really bad AIT's so after nurmerous times of trying to get it worked out...he decided to put it back stock and let his wife drive it...
as far as the lexus is going....oh yeah man...the car is a dream!!!
i would not have it any other way! i will get some pics up pretty soon of my setup and how its running....i also have a few videos as well to get up....
hows life been here on the boards? anything new happening?
also...hows your car holding up
My car is holding up well. It was running a little lean at full throttle (13.5:1) so I had the ECU settings to Stage 3 and 91 Octane changed and that cause misfiring and lost 17hp so that is being change again today to "base" octane and Stage 2. Hopefully that will work. Several board members bought the ASP pulley, a few have received them and I know of one that installed besides me. Too bad your mechanic couldn't produce a s/c pulley for the masses.
What turbo did he put on (T3?) and how did he fabricate the exhaust manifold? Any pics of that setup? What power did he produce?
he used a small mitsubishi 16G turbo, he had it custom fab. in miami fl (someone he knew) and was producing 314 rwhp.
he might have some pics...we are not really talking anymore....
see..when i sold him that car...the deal was he pay me half, and then once he got it back up and running he would pay me the rest...well...he never paid me the rest....
i have a lawyer that is writing everything up for him...i hate to sue people (even more so with friends), but he has not returned none of my email, faxes, phone calls, or anything....im really not wanting to take him to court...just hoping that he gets scared and sends me the rest of the money....
This new pulley you are talking about ASP...who made it?
Originally I've got was 197hp and 214 ft-lbs torque at the wheels. Since the ECU changes it's been way down. The 108 degree heat doesn't help matters either.
