Instructions on how to take center console apart?
Old Aug 12, 2002 | 03:38 PM
hawk's Avatar
Anyone has instructions/pictures showing how to take the center console apart (with the cup holder, cigarette lighter, etc.)?
Maybe instructions on how to put on aftermarket dash kits would work.
And do you guys know if I will be able to access the cigarette lighter's wires after that?
Thanks.
Old Aug 13, 2002 | 12:22 PM
theLeland's Avatar
C 230 K
pictures and such
I think I have the pictures somewhere on my computer ... send me your email and I'll send you the zip. In past threads there are some details as well.
Old Mar 5, 2003 | 08:51 PM
Blaxer's Avatar
Removal of center console / storage compartment.
Does anyone know how to remove the center console storage compartment on a C230K. I know if you remove the little piece of "carpet" in the lower compartment there are 2 bolts. Is that the extent of it?
TIA
Blax...
Old Mar 5, 2003 | 10:23 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
there's more to it than that. You have to remove the shifter, the wood trim around the shifter, the rubber pad at the bottom of the cupholder, the cupholder. Then unclip the cigarette lighter housing and remove the sliding cover. Then remove the ashtray, the center vent assembly, the wood trim around the radio. There's two bolts behind the shifter, the two screws in the storage bin, two cam screws at the front of the console. Then be REALLY careful separating the console from the dash, it has a tendency to hang up.
Old Mar 6, 2003 | 12:32 PM
Blaxer's Avatar
How do I get the cup holder out?
Old Mar 6, 2003 | 09:41 PM
mbtech208's Avatar
Remove the rubber pad at the bottom of the cupholder compartment, then extend the cupholder and rotate it clockwise while pulling it up and out.
Old Mar 14, 2003 | 05:28 PM
session's Avatar
2007 VW GTI
Center console trim removal
Anyone know how to remove the center console trim (the trim around the gearshift and the cupholder)? When my car was in the shop last time, they didn't re-wire the lighting for the auto gearshift (to display what gear you're in) so I want to fix it.
Old Mar 14, 2003 | 06:21 PM
DaBeze's Avatar
Session, when/if you do this that would be great if you could do a write up similar to the Audio 10 install. With time permitting of course
Old Mar 17, 2003 | 10:37 AM
session's Avatar
2007 VW GTI
Old Mar 17, 2003 | 10:50 AM
Lynn's Avatar
Session, open the ashtray door, grasp the front of the the trim piece and jerk it straight up. Then pull it slightly toward the dash so the back of the piece comes out from under to console.
Now, how do I latch the clips above the ashtray?
Old Mar 17, 2003 | 11:24 AM
session's Avatar
2007 VW GTI
You mean the little metal clasps connecting the trim around the radio/HVAC? If you look closely, there are "hooks" that they connect to. It took me a while to align those metal things and you have to push them back pretty firmly to get them to snap onto the hooks, but they'll eventually get there. Just make sure the clasps are alligned properly and they should just snap back in place.
Sorry I don't have pictures, but when I installed my stereo I didn't remove the ashtray and thus there was no room to even take a picture.
Old Mar 17, 2003 | 11:33 AM
MB-BOB's Avatar
Admin Alumni
See Garage
You shouldn't need to remove everything to reconnect the plug to the shifter console. Use a credit card to wedge between the shifter plate and wood (or alum) trim and twist slowly. Work around the bezel and it should pop up. The socket for the wire is on the underside of the bezel. If the loose wire and connector is visible in the space below, it should be easy to pull the wire up and reconnect it to the bezel. Then snap the bezel back in place.
You can remove the wood trim as noted above. But that might not be necessary if the loose wire is visible through the shifter hole.
You've probably already done all of this. Just documenting.
Old Mar 17, 2003 | 01:00 PM
session's Avatar
2007 VW GTI
Nope, I haven't tried anything yet. Thanks for the tip, Bob!
I'll definitely take pictures if I decide to take my console apart.
Old Aug 25, 2006 | 01:45 PM
Sorata_kh's Avatar
CLK200K Avantgarde 06
Instruction ZIp file
hi
COuld u please send me the zip file, bcos my consol button is destroy by the perfume and iw oudl liekt o remove and clean it bcos there are still liquid inside the button.
thank you so much
my emial is : piseth27@hotmail.com
thank u so much
Old Nov 15, 2007 | 12:34 PM
merc200k's Avatar
c200 kompressor
how can i remove central conslole at w203
pls any advise to do it? pics pls how remove the central console..ty
Old Nov 15, 2007 | 12:44 PM
edtv82's Avatar
From: dayton ohio hopefully it will be some place warm and sunny when i finish med school
2002 C32 AMG silver & 2003 Lancer Evolution 8 black very moded
https://mbworld.org/forums/showthrea...=1#post2264959
the basic idea... did you search the forum?
Old Nov 15, 2007 | 12:51 PM
jolenicz's Avatar
2002 C230 Coupe
Actually, that thread isn't the basic idea for the center console. It does give a great description if you want to remove the center of the dash, to replace the headunit, or the climate control module or something up there.
If you really meant the center console (rear of the shifter, the ashtray and storage compartment), I'm afraid I've never seen a good post on that. I looked into removing it myself when I was installing my stereo, and I never figured out how to remove all the parts.
Generally, when someone wants to remove the center console, they have a reason, like to install a device inside the console. Sometimes there is a good way to install the thing without completely removing the center console. If you can describe what you are trying to do in detail, there may be someone who has a good method for you.
Bear in mind, though, that I have never seen anyone describe how to remove the whole center console.
Old Nov 15, 2007 | 12:52 PM
mleskovar's Avatar
'17 Jaguar XF
https://mbworld.org/forums/c-class-w203/177068-noisy-air-conditioner-stepper-motor-replacement-clicking-hissing.html post #18
