C230 Door Panel
Old Aug 18, 2002 | 03:31 PM
ahwang's Avatar
2002 C230
C230 Door Panel
Hi, How many screws do I need to take out in order to remove the door panel? I find one screw behind the SRS badge and one is just under the black handle. Is there any other screws I need to remove? Thanks!
Old Aug 18, 2002 | 05:22 PM
DtS's Avatar
DtS
C200 Kompressor
Hahaha, Didn't you ask the very same question a couple of days ago?
Check out: Removing the door panel
Old Aug 18, 2002 | 08:57 PM
ahwang's Avatar
2002 C230
Yes, it was me.
cuz I tried to unscrew them and tug the panel upward. I couldn't make it. If I tug it too heavy, I am afraid I gonna break the panel. Is there any technique to remove the panel?
Old Aug 19, 2002 | 01:52 AM
Freddy's Avatar
Did you remember to remove the U-shaped plastic trim around the lock-mechanism? And are you sure you have unclipped all clips before pulling the panel upwards?
