2006 fitment rims?
Old Jun 5, 2006 | 06:47 PM
Casanova0713's Avatar
2006 fitment rims?
Hello again...man im having a problem...i have been calling place after place and they all tell me that the c230 2006 brake calipers are too big to fit a regular style rim and that i need a "3 piece" but i have no idea what that means or what brands make those....why cant those companys just make rims that fit why do they make it more complicated.....
Old Jun 5, 2006 | 07:41 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
I have a set of rep m o n o S that will fit the 06 c230.
also I have my personal 1/16 BE Carlsson for sale as shown in my sig.
PM me.
Old Jun 5, 2006 | 07:57 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Simply put, there are 3 types of rims available on the market:
1 piece, 2 piece, 3 piece. 2 main types of metals used to make the rims (forged or cast iron).
1 piece rim is exactly as it sounds (all the metal is one piece formed into a wheel configuration)
2 piece rim is made of 1) the portion of the wheel that is surrounded by tire and 2) the center piece (what you see when looking at rims on a car).
3 piece rim is made of 1) Inside portion of the wheel, 2) outside portion of the wheel, and 3) the center piece.
You don't necessarily need a 3 piece rim to fit the front brake calipers, but you do need rims with the correct offset in order to work. You can find 1 piece rims that'll work, you just have to do the research.
Old Jun 5, 2006 | 08:10 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Sorry Drex,
But as others on here have already pointed out, offset is only part of the equation. The design to leave enough room to cover the increased rotor/caliber diameter also comes into play. Lets look at it this way;
1) Both wheels have the same OFFSET
2) Both wheels, maybe from different manufacturer's, use the same process
3) Wheel 1 is designed for x" of rotor/caliber clearence
4) Wheel 2 is designed for x+y" of rotor/caliber clearence to make allowance
Old Jun 5, 2006 | 08:19 PM
drexappeal's Avatar
Originally Posted by amdeutsch
Sorry Drex,
Yeah, that's true amdeutsch, but the shop is tellin' the guy that he needs to get 3 piece rims in order to fit anything onto the car due to the front calipers. That's not necessarily the case. I was just trying to let him know that there are 1 piece rims that will fit over the stock front caliper, but just gotta do research first (including pre-fitment) before having to spend an extra 2 or 3 G's on 3 piece rims.
Old Jun 5, 2006 | 08:26 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
But all you specified up top in your post is, and I quote, correct offset in order to work. Sorry.
Old Jun 5, 2006 | 09:10 PM
drexappeal's Avatar
Yeah, my bad. I tried to "over" simplify, since Casanova0713 didn't know what a 3 piece rim was.
Old Jan 1, 2007 | 08:22 PM
wluk's Avatar
Will the 2004 c230 sport wheels fit on a 2006 c230 sport? I need a set of winter wheels/tires. Thanks.
http://cgi.ebay.com/ebaymotors/ws/eB...7584608&rd=1,1
Old Jan 1, 2007 | 08:24 PM
rlee02135's Avatar
2004 C32 ///AMG
yes
Old Jan 1, 2007 | 08:25 PM
wluk's Avatar
that was quick....thanks rlee02135
Old Jan 3, 2007 | 02:12 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
just ask the seller if it's gonna clear ur front bbk before you purchase it.
and yes, the 04 c230 wheels will fit 06, in fact, I think they are the same wheels
Old Jan 3, 2007 | 06:34 PM
wluk's Avatar
I figure it is safer to ask here. They will tell you everything just to make the sale. In fact, 2006 has different wheels. I guess I will find out when they arrive next week. thanks
Old Jan 3, 2007 | 06:53 PM
rlee02135's Avatar
2004 C32 ///AMG
those wheels will clear the BBK
Old Jan 3, 2007 | 08:19 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
really i thought 03 has different wheels(7 spoke)
04-06 has same set
and 07 has another new set
could be wrong
Old Jan 3, 2007 | 08:46 PM
drexappeal's Avatar
04-06 has same set
could be wrong
2003-2004 C7 wheels Non-staggered (no front caliper upgrade)
2004.5-2006 Adharaz staggered (4 piston caliper for 2004.5-early build 2005 / 2 piston caliper for mid-late build 2005-2006)
2007 (don't know the name of them).
