03 C240 -- questions regarding headlamps
Sorry to be a newb, I'm new to the forum and to mercedes in general... Right now I've got an 03 C240 w/ standard non-xenon headlights w/ the non-clear headlamps....
Currently I'm just looking to upgrade the headlamps to the clear ones... I was wondering if clear OEM headlamps off a 2005 (w203) C230 would work for my car...
Thanks much, any reply is appreciated
-Matt
if u want to add HID, u can get HID kit from CarLAB...
if u want OEM bi-xenons, ask steve@MBenzNL.com
Yes, the halogen (non-xenon) clear lamps on the newer models will work (plug and play) to replace the older faceted headlight assemblies. I have '06 lights on my '01. I got them from a friend who upgraded to the BiX. Maybe someone else here has their clears sitting around after a similar upgrade and will cut you a deal.
The hardest part was dropping the front bumper to install them. Or I should say it wasn't hard, but tedius. The trick is not to remove the bumper completely, but to remove the fasteners on one side 2/3 of the way across the car, drop that side, install it's assembly, reinstall the fasteners, then do the other side. It keeps the bumper aligned. You can search these forums to find step-by step instructions.
You'll find lots of folks here who like the looks of the projectors (xenon or not) within the "Mr. Peanut" assemblies. I for one, do not like the look, and the clear halogens accentuate the shape of the design better, IMO. To each his own.
Regards
Darwin W
