Steering wheel controls - aftermarket unit NO ANSWER
Old Nov 4, 2007 | 01:22 AM
  #126
Hksuperman4000's Avatar
C320 Sports Coupe 2003
Hey
Hey guys so I was on ebay looking up this mod here and came across this. Its suppose to do the same but more then less then half the price of the other ones from another country. Any thoughts on this guys?
http://cgi.ebay.com/Retain-Steering-...QQcmdZViewItem
Old Nov 5, 2007 | 03:48 PM
  #127
Davideo's Avatar
2012 E350 4Matic Wagon
That eBay site says it will not work with Mercedes... (see link at bottom)
Old Nov 6, 2007 | 01:13 AM
  #128
Says wont work on 05-07 mercedes but what about older models? I just emailed him so I should get an answer soon thanks!
Old Nov 6, 2007 | 11:27 AM
  #129
WaveyKat's Avatar
Something Slow
i install the CA-R-PI.131 but i have an Extra "E" in PIONEER mines look like this "PIONEERE" but it work great. has anyone had this happen or can fix this?
Old Nov 6, 2007 | 12:11 PM
  #130
faboR6's Avatar
C240
Not sure if this may help but I've use this one and works perfectly for mine a JVC;
Pacific Micro PAC SWI-JACK JVC/ALP/CLARI/KEN Steering Wheel Radio Control Interface Allows you to control select Alpine, Clarion, JVC, and Kenwood stereos with your factory steering wheel controls, splicing required
http://www.crutchfield.com
Enter your information and it will tell you if your aftermarket stereo system is compatible.
Old Nov 10, 2007 | 06:47 PM
  #131
cla 1000's Avatar
2002 C230 K, 6 speed
Originally Posted by jgsx
Swapping over to an aftermarket head unit is a large job if your car has the Bose audio system. You'll have to ditch the stock sub/speakers (or at least use new amps)
That is not quite true. I am running the bose speakers on the AVIC D2 and they work flawlessly. I am looking to upgrade to some other speakers now but I have been running this setup for over a year now. The speakers are powered by the pioneer HU and the bose sub in the trunk is powered by a sony amp that my budy put in.
All u have to do is to get the speaker wires from the head unit in the back to where the Bose amp was. Here u need to connect the speaker wires together and that's it for the speakers.
The bose amp will not work with the pioneer or any other aftermarket unit because of the fiber optic connection, but, u can take it out and replace it with a regular small amp so u can power aup the sub in ur trunk.
That's it.
Now to my question: Anyone here using MB Quart speakers? How are they?
I want different speakers and not sure what to go with. I do not want to spend a lot of monney on them either.
I know I read somewhere that someone was using MB Quart and now I can't find that post.
Thanks in advance.
Old Nov 11, 2007 | 09:46 PM
  #132
kouka86's Avatar
I have the same thing. Anybody know how to fix this?
Old Nov 12, 2007 | 12:37 AM
  #133
jello's Avatar
2002 Mercedes C320, added OEM Bi-x, clear side markers, Bilstein + Eibach Pro Kit
Bose speakers
So anyone know how to tell that you have the Bose speakers? Thanks!
Old Nov 12, 2007 | 08:42 AM
  #134
WaveyKat's Avatar
Something Slow
Bose speakers or BOSE SYSTEM?
Old Nov 12, 2007 | 12:01 PM
  #135
jello's Avatar
Bose
I guess the Bose system... Whatever it is that would cause you a problem wiring an aftermarket HU due to the optical connection to the rear speakers/woofer?
Thanks!
Old Nov 12, 2007 | 01:19 PM
  #136
WaveyKat's Avatar
Something Slow
to find out if you have the bose system look on the rear deck speaker and see it there is a BOSe logo on it if not check in the trunk on the right side Panel under the carpet if u see a black AMP then u got bose system and if you have the bose system read Post #24 in the thread. https://mbworld.org/forums/showthread.php?t=212894
Old Nov 14, 2007 | 09:10 PM
  #137
mbdragon55's Avatar
2001 Mercedes Benz C240
can someone post step by step instruction on how to install this thing? what do i have to take apart??? thanks
Old Jan 24, 2008 | 07:13 PM
  #138
c32used's Avatar
LET C32 2002
That's it.
Thanks in advance.
Hey cla 1000 what install kit you used? I bought the Kenwood DNX7100 and wondering how you spliced amps in please tell me how. What adapter are you using for the steering wheel controls I don't recall reading it.
Old Jan 25, 2008 | 12:10 AM
  #139
c32used's Avatar
LET C32 2002
Originally Posted by riderman
Okay, I just made a small clip for the ones who don`t believe me
http://www.unika04.de/priv/MVI_0493.AVI
I didn`t use every function, only "next track" And "volume +" -
all other functions like "last track" and "volume -", fast forward/reward (by pressing the next/last track button for more than 1,5 seconds) and when you are in Tuner mode frequency +/- and station-searching by pressing the next/last track button for more than 1,5 seconds work too - you joust have to believe
Sorry if I missed it in the prior replies but what steering wheel adapter are you using? I am trying to find one for my Kenwood DNX7100 GPS/DVD NAV. Also what installer kit you used?
Old Mar 9, 2008 | 12:16 PM
  #140
Kobazz's Avatar
CL203 (2001)
Hi, here you wil find a list with all compatible adapters. http://www.kenwood.nl/support/swrc/
Old Mar 9, 2008 | 03:47 PM
  #141
WaveyKat's Avatar
Something Slow
ok so today i took the Black Terminal off the Battery to Reset the Clock For Daylight Saving time and Poof the Cluster Doesnt Say "PIONEERE" its PIONEER its spelt the right way now... so anyone who have this problem its an easy fix!!
Old Apr 20, 2008 | 11:57 PM
  #142
c32used's Avatar
LET C32 2002
Ok if the Car:Pi is hard to come by then you can use the Pac-Audio SWI-X WITH SWI-CAN. Also available thru ebay...as a side note I believe the Pioneer unit will show " Pioneer " while the Pac-Audio shows a blank screen...
Old Mar 23, 2009 | 02:32 PM
  #143
ItsFlip...'s Avatar
2005 Mercedes Benz C230
So i'm new to this but i have done endless hours of research and I know I need the Pioneer CA-R-PI.133 for my 2005 C230 steering wheel control. I have already bought the F90BT, Scosche wiring harness, Scosche antenna adapter, and dash kit.... All im missing is the steering wheel control. How much do I plan on paying for this? I head about 65 Euro..... about 95 USD. Is this correct? And does anyone have a reliable link for this part? All the ones i have seen have given me an error that it doesnt load. One other thing has anyone heard of the PAC Module (used for same purposes as Pioneer CA-R-PI.133 ).... reliable? Thank you and God bless
Old Mar 23, 2009 | 02:38 PM
  #144
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
I did a bunch of research on this too, when i was thinking about getting the F90bt. The only place i really found it was on ebay from an international seller. He was selling it for $150 + $10 shipping
http://cgi.ebay.com/ebaymotors/PIONE...fAudioQ5fVideo
check out the aftermarket head unit thread, there's some info there about the Pioneer and PAC modules..
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
