Brake pads
Old Nov 7, 2006 | 10:54 AM
PsiTERROR's Avatar
2003 c230k sport 4 door
Brake pads
I've been searching for my answer but I can't find it.
I have a 2003 c230k how many sensors do I need to get at the dealership so I can change the pads myself? Is there one for each caliper?
Old Nov 7, 2006 | 10:59 AM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Only one sensor, in passenger's side inner pad.
(Although, if your sensor didn't activate - and you don't damage it during pad removal, you can reuse the existing sensor)
Old Nov 7, 2006 | 11:21 AM
PsiTERROR's Avatar
My brake pad wear message came on.So that means I should also change the sensor right?
Old Nov 7, 2006 | 11:32 AM
dmatre's Avatar
Correct.
Old Nov 7, 2006 | 12:05 PM
tee_tz's Avatar
ML63 AMG
Where can I get OEM AMG Brake Pads? And what components do they include, maybe I can try searching the web for each components. And if anyone has done it - or at least knows the pricing, just let me know, thanks.
I have a C320, just in case that makes a difference.
Tee_Tz.
Old Nov 7, 2006 | 06:07 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Tee_Tz.
Can't just get the AMG pads without changing your calipers. The pads won't fit on the OEM 320 calipers. If you want AMG pads, you have to do a swap to AMG Calipers and rotors.
But, just for reference, OEM pads are usually made by PAGID and/or one other company (can't remember the name off the top of my head).
Old Nov 8, 2006 | 08:48 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
Hope this doesn't qualify as hijacking the thread, but my "brake lining wear, visit workshop" message just came on as well, and I find that I can't "dismiss" it, like I can with a "low fuel", or "light out" message. I figured i would wait till I put my winter wheels on to do the brakes, but the message is driving me crazy, blocking my speedo, odo, clock, etc. Is it supposed to do that?
Old Nov 8, 2006 | 11:19 AM
drexappeal's Avatar
eddie, it will stay on until you get the pads and sensor changed.
Old Nov 8, 2006 | 05:14 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
will that just show up like one of the mulfunction, like when the gas is low
Old Nov 8, 2006 | 05:27 PM
eddieo45's Avatar
yeah, but unlike "low fuel", you can't just page by it and get on with your life. It keeps coming back (unless your foot is on the brake), which is a b*tch when your trying to see your miles travelled or the clock or something.
Old Nov 9, 2006 | 11:03 AM
fanito's Avatar
02' C230k Sport Coupe
Mine is currently on and I just wait 2 minutes and scroll to the next menu. Everytime you start your car it will show and sometimes it will go off if you break hard... go figure.
Old Nov 9, 2006 | 11:14 AM
BIGjohnny's Avatar
/////AMG
From my experience through E320, S500, and currently C230. You have approximately 1000-2000 miles left on your brakes, depending how you drive.
Old Nov 9, 2006 | 11:15 AM
BIGjohnny's Avatar
/////AMG
Sensor only cost 3 dollars. All you need is one.
However, once i forgot to purchase the sensor and just reused the old one. Worked fine.
Old Nov 10, 2006 | 11:39 AM
eddieo45's Avatar
I scroll to the next menu, but the brake alert comes back--no matter how long I wait.
1000-2000 miles is plenty; snows will go on in December.
Had the sensor "activated", that is, produced the "brake wear" alert, before you reused it? I was under the impression that once it alerts, it's toast.
Old Nov 10, 2006 | 12:20 PM
drexappeal's Avatar
For a $3 sensor, I'd say it's better to be safe than sorry. If it worked for Johnny one time, doesn't necessarily mean that it will consistently be that way for all the other sensors.
Old Dec 7, 2006 | 12:10 AM
Ryanr317's Avatar
R129, XF Sportbrake, SC400
Just wanna make sure. Is there a difference in the pre 2004.5 sport model brake pads and the luxury model pads?
