question for manual drivers
i got my 2003 c230 coupe from my sister just a couple months ago and this happens to be my first manual car. i know how to drive stick, but have noticed something peculiar when i start driving....
whenever i first put in the clutch and try to shift into first, the transmission sticks... in other words it feels rough/resistant for me to put it into first. after that everything is smooth like always. even after i switch back into first once the clutch is active, there is no resistance.... but once i break and take off the clutch completely (like at a stop light) and try to start in first again, it resists letting me put it in first all over again. i tried this many times yesterday on my drive home from D.C. at every light and it always happened.
does anyone else have this problem or notice this? and do you think this warrants a visit to the mb dealer demons ? (my car is still under warranty).
C32
I've driven two manual cars: 97 Acura Integra GSR and 00 Prelude, and the above symptoms are fairly common.
Usually when you just startup the car, engaging in first is usually harsh by nature. If you don't come to a complete stop (i.e. coasting), it will be almost impossible to put it into first. Suffice to say, it will only be smooth is the car is completely stopped. You can also try double clutching (step on the clutch twice) to see if it helps.
thanks for the input ultraseven....
if i understand correctly, you said that it will only be smooth when it is completely stopped (while running) and that it is common to be hard to put it into first when just initially starting the car?
my problem is that every time i put it into first to start moving and press in the clutch from rest, first gear is harsh (regardless if it is an initial start--when i turn on the car OR an intermediate start--at a stoplight).
the only way i can make a transition into first smooth is if i leave the clutch in when i stop at a light and not take it off until i go into first to start moving again. i was wondering if that is common.
thanks!
thanks!
'05 A4 1.8TQM6
most cars have 1st locked out if you're going faster than a certain speed to protect the tranny. Usually its 5mph or higher, you should feel resistance trying to get into first. Being completely stopped or 1-2mph should be easy to get into first.
I would do this: turn off the car and clutch into 1st gear, see if there is any resistance then, if so, I think there's a problem. Otherwise I'm assuming the car has fully warmed up, because when my car is still somewhat cold, gear 2 can be a little stiffer (than other gears), so it depends.
Tee_Tz.
2007 C230 Sport manual
Mine does that, too, but only when the transmission fluid is still cold.....what you do is wiggle down to second and then up into first...that works...but this is only when fluid is cold, as I said.....mine is smooth once it is warmed up...it is minor annoyance....but I do love my Merc manual.
good points...
i just want to make clear that i only tried going into 1st when the car was stopped (not coasting)--not moving... and this was when i noticed it would stick. the determining factor which would make it stick is whether or not my clutch was previously engaged.
if the clutch was not held in from before the stop and then i press it in and go into first --> it sticks (even when the car is warmed up!).
if the clutch is held in from when i stop to when i start again, then it is smooth.
it just doesn't seem natural to always have the clutch in in order to have a smooth shift into first at a stoplight.
does that make sense?
'05 A4 1.8TQM6
good points...
'05 A4 1.8TQM6
LOL, take it out and do some poses anyways
good points...
thanks GDawg,
i will try a few things when i go out later...
-putting it in gear before i start the car
-waiting a little longer after i press on the clutch and before i shift
-and i will try again after i driving around for a while after my car is warmed up
i appreciate the advice... if all else fails i'll go to the dearship and ask them to check it out.
'05 A4 1.8TQM6
thanks GDawg,
Did you say your brother has an SLR!?
Tee_Tz.
'05 A4 1.8TQM6
Hmmm, 39k, the fluid should be okay. But give those things a try and see what happens. Hope you don't have a more serious issue. Could be the shift linkage needs to be greased or something, might be possible. The older manual transmissions were cable linked.
BMW 135i
The reason is because the synchros are engaging to stop the transmission inards from spinning. First is a very tall gear as well. If you do second then first you will have no issues. Since second has stopped the transmission inards from spinning already. Also if you clutch in and leave it in for several seconds thus allowing everything to stop spinning then it will slide in easier as well. This is normal and nothing is wrong. Mine has done this since day one. I actually always engage second then first though so it is not noticed. I have done this whenever I drive a standard shift car so it is second nature to me.
C320 Coupe
that's why i usually start my car from 2nd gear. When you stop, sometimes you can't even shift into 1st gear no matter how hard u try, in this case you shift into 2nd gear then back to 1st, then it will go in again. as for resistance, i don't use my 1st gear more than once every week, unless sometimes im feeling high and do heel toe into first gear lol
i do have another question for you... when trying to drive fast from start, how high should i rev in each gear?
i heard that max torque occurs around 4000 rpm, so if i want to have fun with my car... is it fine to run up to ~4000 in each gear as i climb my way up?
2005 C230K Sport Sedan, 6 speed manual
Now the bad news. The official MB transmission oil costs about $30 per liter, and you will need to buy 2 liters (actually holds about 1 1/2). I highly recommend changing the transmission oil (and also the differential oil) about every 30,000 miles. The transmission oil and the differential oil are different, so don't get them mixed up.
The good news. Changing the oil is a lot cheaper than transmission work, and it has a high success rate. Either have the dealer do it, or buy a 14mm and 19mm Allen wrench and do it yourself. The dealer may give you a speech about the "lifetime fluids", so you may have to insist.
If changing the transmission oil doesn't work, you may have more serious transmission issues. MB had a few problems on the early 6-speed trannys with the "dogleg" reverse gear (pull shifter left and back).
C320 Coupe
phew... thanks man, i've driven stick before... but this is the first stick i've owned, so i'm starting to pick up on these little things.
