ATTN w203 EBAYERS
Old Jan 23, 2007 | 06:11 AM
kardician's Avatar
Originally Posted by Mercus
I have Xenons on the SL and had one blow out two months before the end of the warranty. Would have cost me $2500 to replace, hence the reason I stuck to regular lights on the C230....
Is there a list of things that are / are not covered by the original warranty? I have a list of things covered under the extended warranty and bulbs are not covered.
Old Jan 23, 2007 | 10:50 AM
C24owner's Avatar
'08 E550 4Matic
Originally Posted by Moviela
...When C24 turns on his high beams, night turns into day NOT because of the BIX lamps. The high beams are halogen lamps in a properly designed reflector, and that is what illuminates the road ahead so brightly...
even with out the high beams my 10000k bulbs light up the road very well. I dont even use my high beams. I'll try to post a pick tonight of both the normal driving lights and high beams
Old Jan 23, 2007 | 12:33 PM
sirenebekim's Avatar
i know sometimes people have HIDS and i can't see when im going around a corner, a hill, whatever.... Kinda dangerous in a way.. its great if one driver can see 100%, but if the other can't see *****, and hits you in your lane like a moth driven to the street lamps, whats the point in the lights?
Old Jan 23, 2007 | 01:45 PM
C24owner's Avatar
'08 E550 4Matic
As long as you have a good projector and they are adjusted properly then you should blind oncoming traffic. I haven’t has a single person flash their lights at me, yet.
Old Jan 23, 2007 | 02:01 PM
will i have problems with it if i dont install the auto leveler
Old Jan 23, 2007 | 02:14 PM
C24owner's Avatar
'08 E550 4Matic
Nope. I don’t know of anyone that installed all the other stuff when retrofitting the bix.
Old Jan 23, 2007 | 03:32 PM
  #32
http://www.thezomkspeed.com/ he has the damaged headlights if you like them cheaper this is your thing then go for it but im just warning everyone that this is the source of the foul headlights.. They may not all be foul, however, I recieved foul headlights.
Also, when I talked to them again,, they said they had a whole shipment of lights that are possibly damaged.. I dont know how long it will take to get new ones, but if you do order from him, b/c it is a really good price, call ahead and ask them to pre-check your shipment before sending it out, and to specifically check for the projector being malfunctioned.
When i first called and told them I had problems with the headlights quality, they asked "is this with the projector unit"... They knew before i even told them
Where's the business ethics here?? WTF advertise new, but know a percentage of the units are damaged...
WOW
