Brake pads Change with no warning light..HELP!!!
the mileage is 29500 miles..is it too early for pad changing or really over due..
Not sure how long pads are meant to last..
PLEASE HELP.!!..hate to spend for something i really dont have too..
Tell the mechanic to show you the diagnostics that say the sensor was triggered. If he can't...or won't.... respond by asking if the brakes wore out early because they are defective. Then ask them to replace the pads under warranty. If the service manager balks at that, ask to speak to the general manager.
question also arises..why is it when i brake, you get a grinding "whoo..whoo" noise..what is the possible cause of that if it is not brake wear..
do i need to go on another holiday and come back and maybe the noise might go away..just kidding.!!.
i might check this with another mechanic to get a few opinions..just got this strange feeling my wallet is going to be lighter pretty soon..
The pads themselves will be servicable down to about 3mm. Even at that point there is no need to rush to the workshop. A few weeks would not be an unreasonable delay.
In the past rotors were expensive, hard, and had a bit more "meat" on them. It was possible to machine the rotors flat a couple of times for smooth braking. Truth was that workshop refinishing equipment was it is not very precise, and the situation often went from bad to worse.
Now rotors are softer, designed to be sacraficial, and usually wear to being too thin to need workshop machining. The good news is that price of a rotor has dropped from 200 down to 50 quid. (plus VAT, the *******s!)
I find with German marques that the rotors are useful for two sets of pads, and then need replacement because they are near the minium thickness.
It is quite easy to change the brake components. If you know which part of a spanner is for your hand, it should be easy to do it yourself.
Plus, we all drive differently and in different settings. I'm always on the stop and go traffic...DAMN S. CALIFORNIA! My "Brake Wear" light comes on at around 21-22k miles. Hope that helps.
Not from those pics, you need a picture straight from the top of the caliper looking down. You need to see the thickness of the pad material edge. A pad is made up of two pieces, the thick metal backing plate, about 1/8" thick metal. Attached to the face of the backing plate and touching the rotor is the pad material. You can see the outside pad with the wheel on but to see the inner pad you need to remove the wheel and look in the pad inspection hole which is on top of the caliper. Unless you are replacing the pad because you don't like the pad, ie. it gives off too much dust, then wait for the sensor to go off. No additional damage will be done to your rotor because you waited and even then so what, rotors are cheap and I usually replace them when I do pads. I just ordered rear rotors for my kid's SLK, made in Germany, $34 each, free shipping, no sales tax. It would cost me $15 each to get them turned and then wait an hour while they do it and they are still rusting and dirty. Not worth the hassle and my time.
VERY doubtful.
Front pads is much more likely.
If you wait till the light comes on, you'll have about 1000 miles to
get it done.
But don't wait till it's at the metal.
Could be pad wear. Try a different mechanic?
