bought the CD changer from Phattbam, now need help...
Old Apr 1, 2007 | 12:02 AM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
ok after reading session's audio 10 install thread i am up to the place on how i plug my CD changer in now...
the part i am in is the "fiber optic" cable
this is a mess i am making atm
this is the fiber optic and the back of my audio 50, the fiber optic cable read "radio in"
so do i use that cable and connect my CD changer?? or phattbam missing me a cable??
also STFF found this
http://www.mbklasse.com/forums/showt...&threadid=7020
would it be in the trunk?? or
Old Apr 2, 2007 | 11:35 AM
ML55CLA45's Avatar
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
sorry.. skimmed your post... put yeah.. you need to get some FO cables from the trunk.... in the plastic cover compartment in trunk.. in front of the spare wheel...
that FO cable with the RED and white end that was plugged into your HU... you need to split... those should be the speaker out.......
leave the RED one with the HU and run the white one to the changer.... then take the other FO wire (from trunk) and then run it from the CD changer to the HU...
and then you should be good to go...
i just recently installed the euro nav in my car and this was how the wires were.....
good luck..
carino
