Ignition Hesitation
Old Sep 30, 2002 | 11:57 PM
PoonerElRay's Avatar
2017 GLA 250 4Matic
Ignition Hesitation
I've had the car for about 4 months now. As of last week, several times when I start the car, it takes longer for the engine to start up. I notice that when I turn the key to the ignition position, the sparkplugs take longer to turn the engine on.
Normally, it turns on almost instantly, but in the above incidences, it took say 1 second longer. You can hear the engine struggle to start up.
What's wrong?
Old Oct 1, 2002 | 08:31 AM
Jerry MB230K's Avatar
cold weather ?
Old Oct 1, 2002 | 08:40 AM
I've had several occasions when the car started and idled very rough for the first 15 seconds after starting. Also, once, the starting cycle timed out , then I tried again and the car started.
I think this is more of a problem in cold weather.
Old Oct 1, 2002 | 11:36 AM
2017 GLA 250 4Matic
I thought I was the only one with this problem. If cold weather's the cause, then I'm not too sheeshed about it.
Old Oct 1, 2002 | 07:07 PM
trench's Avatar
2002 C230 K
Originally posted by C230Jeff
I had this sort of problem, also only once. It happened to be a day or so after I installed my ASP pulley, so I was a bit concerned that might have been somehow related, but it has not happened since. That morning was not excessively cold, maybe 60 degrees, and I do think it was also a wet day. The behavior was a very rough "attempt" at a start, a sort of sputtering, and then the engine died without fully starting. I immediately restarted and it was fine. Again, this happened only once, and not since.
I had essentially the same thing happen as you described, Jeff. The weather was probably around 55-60 degrees and dry; however, as I had been driving the car shortly before (it maybe sat for an hour), the motor should have still been relatively warm. Upon starting the car sputtered and shook rather violently, I immediately shut it off. It started normally a minute later. It's never done this since (about 5-6 months ago).
Most embarrasing - I was in a parking lot and there were cute girls walking by.
Later, BT
