Braking Noise. Need Advice.
I got this brake noise when I go slow like 5 - 10 mph then brake it. the sound are so annoying, like old car noise or when I reverse my car. I went to dealer and they said they can't find anything wrong. The brake is still 75% left they told me. I am not sure if anyone experience this? Anyone installed Brembo? thanks guys.
-Charles
if you complain enough to your dealer ,,he should replace pads and rotors both ft and rear under warrenty.
if your car is still under 12/12000.
if not bg makes a lube that helps noise if you saturate the pads ,and put a non directional surface on rotors.
and chamfer the pads
After the car/brakes have warmed up, ther is no noise. But I still hate it. Grrr!
