Driver's seat for Easy Enter/Exit Not Working
Old 07-13-2007, 06:19 PM
esemes's Avatar
2007 c230
Originally Posted by drexappeal
So weird, cuz I know they took this out in some models.
Man, things keep popping up that some people have and others don't.
agreed....
btw - build date = 06/06 (if this ever would help)
Old 07-18-2007, 04:36 PM
amari's Avatar
Exclamation Driver Seat won't go back... Plesae Help!!
It will move all direction but not to the back.
Any help will be appreciated.
Old 07-18-2007, 07:51 PM
mad_vtak's Avatar
'13 250 Coupe
Have you tried to reset your seat yet?
Old 07-18-2007, 10:34 PM
phranksmbz's Avatar
09 c300 4matic
how do you reset your seats? my passanger seat doesnt move period but my driver side does ... lol never really cared cause i never sit in that seat but since were on this subject lol.
Old 07-19-2007, 12:41 PM
amari's Avatar
eemm no..
How do u reset the seat.?
BTW, thanks for taking the time to respond to the thread.
Old 07-19-2007, 01:02 PM
McDub's Avatar
2002 C230k
If it's a coupe, try moving the seat forward, as if you were gonna get in the back seat. Then push it back where it's supposed to be. My headrest wouldn't go down or up the day I brought mine home because the seat wasn't fully "locked".
Old 07-19-2007, 01:20 PM
  #32
amari's Avatar
It is a W203 2004 Sedan.
I should have mentioned it before...
Old 07-19-2007, 03:15 PM
  #33
diamondblak05's Avatar
Too many to list
Originally Posted by amari
eemm no..
Refer to this thread about resetting the seat. It worked on mine.
https://mbworld.org/forums/showthread.php?t=201223
Old 07-19-2007, 03:37 PM
  #34
pnoye2's Avatar
'03 C240 (the Mrs daily commute)
Blown 30A fuse (Green); happened to the Mrs commute car... there is a fuse/relay/breaker service panel inside the trunk on the left hand side, first you'd need to pry out the outer access cover by hand to expose the panel then pull the actual cover out, fuse puller should be affix to this cover.
You'd be looking for the very top 30A fuse, the one below it is for seat recline.
Hope this helps.
Old 07-22-2007, 04:10 PM
  #35
amari's Avatar
It's working now.
Thanks all for the valuable feedback.
I had to reset the seat.
Originally Posted by patrick_y
Had a failed computer with another Mercedes-Benz car in the garage. Try holding the power seat button to make the lower seat cushion to go forward. Don't release the switch after the seat stops, continue holding the button in the same fashion for another 10 seconds. This resets the computer. This isn't supposed to remedy your situation but it might help.
Sometimes, the oddest things can be fixed with a quick resynchronization.
Thank you diamondblak05 for the Link.
Old 07-23-2007, 10:09 PM
  #36
WhatTheHulk's Avatar
'03 C230 SS
Same thing happened to me 9 months ago. I just read this post and replaced the green fuse. Finally a power seat!
Thanks!
Old 07-27-2007, 03:36 AM
  #37
j3kdragonj's Avatar
Easy Entry Seats
2002 C230 Coupe with the convenience feature. Battery was replaced last month, and since then the seats will not move foward/back when I start/turn off the car. Convenience feature is set to steering wheel and seat, but only the steering wheel moves. I tried to move the seat to full tilt on each axis several times, but still no luck. Suggestions?
Old 07-27-2007, 03:51 AM
  #38
BadAssC230k's Avatar
"Double Stuff" SOLD | Nor*Cals "Pesky Audi"
Try a fuse. that happened to me. Lost the drivers seat and steering column adjustments. Seems it was only a fuse.
Old 07-27-2007, 12:27 PM
  #39
pnoye2's Avatar
Somewhat similar to this thread... hope this helps, goodluck!
Old 02-23-2013, 01:22 AM
  #40
ruben65's Avatar
Seat computer reset worked for me and fixed my easy entry/exit issue. My seat would not back up when key removed, but steering wheel would. (2005 C55)
Perform while outside vehicle with drivers door open:
1. Turn key to "ON" position 2 (right before start)
2. Press bottom seat cushion button forward, once seat reaches the full forward position, continue to hold for 10 seconds. Then release button. (I heard a reset click after 10 seconds, I assume meant it reset)
3. Hit seat memory button you have your settings set to and allow it to adjust to set position.
4. Get in car while seat is in your set driving position, close door, then turn key to off position and remove. (your seat and steering wheel should now adjust to the exit position setting)
Seat should now work with the easy entry/exit feature again.
Old 02-23-2013, 11:02 AM
  #41
Super Moderator
Glyn M Ruck's Avatar
Yes ~ early iterations of this system used to loose their memory & parameters fairly frequently requiring reset & relearning.
Old 10-09-2013, 11:37 PM
  #42
justinanderson's Avatar
CL65 AMG, CLK55 AMG, CLA45 AMG, 560SL, S550
Are you supposed to hold the bottom seat cushion (only) forward for about 10 seconds after it reaches the full forward position, or the whole seat?
Quick Reply: Driver's seat for Easy Enter/Exit Not Working
