did you know?
1993 MERCEDES BENZ 300TE
did you know?
inside glove box on c class vehicles ,in the glove box there is a adaptor point to attach a portable cd or mp3 player
C200 Kompressor
Originally posted by latent
DSMIT - they are a smug bunch on this forum aren't they?
I didn't know about the shifter technique on the 03. Anyone not smug enough to tell me more?
It works like this: Normally you can tip the shifter to the left to downshift (ie. go from D-4-3-...) in steps of one gear at at time and to the right to upshift, right? Holding the shifter to the left, makes the tranny select the lowest possible gear (for max acceleration or max engine brake). Holding it to the right makes the tranny go into Drive again (without any need for going through 1-2-....) Got it? It's all in the user's manual you know
Re: ??
Originally posted by christian655321
NEW CAMPAIGN ON 2003 230 COUPES
what does that mean exactly?
Erik
2008 VW GTI
Re: Re: ??
Originally posted by tifosiv122
A Campaign is usually a nice way of saying Recall.
this comes up on an mbnet report that is run every time your vehicle comes in shop ,,or at least should be .
and is a campaign,,,not a recall,,and not a tsb.
a product update would probably describe it best
2008 VW GTI
not a recall,,and not a tsb. a product update would probably describe it best
THE DEALER IS REQUIRED TO DO THESE IF THEY SHOW UP ON THE MB NET ,,,,,IN OUT OUT AF WARRENTY,DONE AT NO CHARGE TO CLIENTS
JUST ASK YOUR ADVISOR TO RUN A MB NET AND LOOK FOR CAMPAIGNS/UPDATES
sorry for the caps
sorry for the caps
Originally posted by DSMIT
WELL work REQUIRES caps AND i DONT always LOOK at SCREEN
why does mercedes require the service tickets to be written in caps, anyway?
I have an '03 and my girlfriend has an '02. Both Auto trannies. I know my '03 does the optimal gear choice thing. I have yet to try it on the '02.
On a side note. I recently found out (by reading the manual) that the recirculate button on the climate control will open/close the windows and the sunroof. That's integration!
My 03 doesn't have the fresh air wheel between the center dash vents like the 02 does.
Still not sure if the "Rest" feature fully works on the 03. The button isn't labeled and there is no indicator for it. It will however turn the fan on. Just not sure if will pull any heat from the engine.
the recirculation button feature is called "tunnel mode", useful for when you are (obviously) going through tunnels.
