need help W203 amp install with COMAND
Old Aug 23, 2007 | 04:06 AM
benz_addict's Avatar
V12TT
I have the COMAND in my car and I got all the wires installed for the amp except for the RCA Audio in. My amp doesn't have a high converter so is there any other way I can feed audio signals to my amp? Only option is RCA -IN
For the blue turn on lead I made a custom switch to turn on the amp.
Old Aug 23, 2007 | 10:45 AM
electromethod's Avatar
Honda Grom
Search on the forums and you will find that you can use a specific fuse in the trunk for your remote line. What are you trying to do? Add subs to your system? If so, then tap into the existing lines for your signal and use a converter.
Old Aug 26, 2007 | 07:39 PM
V12TT
thanks
I got a converter now, now I need to know the pin outs for the rear speakers to connect it with the conveter. Any help much appreciated
