shock problem
They charge me $152 + fee($7) + tax to replace rear shock absorber. One thing I don't understand is that it is possible ONLY REAR shock can go bad around 8600 miles. I think useally front shocks go bad prior to the rear ones. Correct me if I am wrong.
Thanks,
Sang
I'm just wondering why they charge me...
I couldn't ask when I pick up my car because service manager wasn't there. It was late evening.
Edit: The sad thing is they probably sent in a warranty claim as well and got paid twice.
I am happy....
It is always good to know service manager.
-----I have been in the shop too many times
Thanks guys,
Here's my situation:
I had the rear Brabus swaybar installed on my car. After I drove home, I noticed a rattling and intermitent knocking (knocking was only when going up a driveway or making a sharp turn).
I didn't have time to take it back to the install shop until this past Saturday. When they checked the swaybar, they said that the rattling they were able to fix (I assume that they just tightened the bolts), but as for the knocking, the shop indicated that this might be due to the shocks going bad.
I'm not totally convinced that the shocks have gone bad, however it's possible that the swaybar (due to the stiffness of the rear swaybar) is causing the rear springs to compress more and therefore causing rubbing of some sort.
Can anybody shed some light on this or have any suggestions of what else it could be? I might have to have TEIN put on the stock springs immediately to have it checked, however, I'm somewhat paranoid that the dealership will not cover it under warranty due to the Brabus swaybar.
Any help would be great. Thanks everybody.
drex
now, if your car new and low miles you can tell them what shocks should last longer and it died due to defect and defects are covered under warranty.
.. if your car lowered , they will tell you, you blew it because of lowering springs
- not covered.
- not covered.
2nd, I'm not a newbie, so I suggest read my question a little more carefully and search my name, newbie. I've been around for a while, so I don't need to be told standard b.s. that I can read in my manuals.
I'm trying to find out if there are any "experts" that may know what it could be "other than" the shocks going bad.
I'm aware that if my car is on springs, they'll claim that the shocks went bad due to the aftermarket springs being installed.
Furthermore, please READ THE POST before you try and tell a veteran some information that I already knew in the first place.
The reason I bumped this thread up again was for the 2 purposes, 1) to find out if the problem could potentially not be the shock (since the problem started when I first had the rear BRABUS swaybar installed) and 2) to show newbies that the search function does work and you can bump old topics to clarify the answer you need.
That being said, anybody have any idea what it may be? I had the rear swaybar checked and after tightening all the bolts, there's no more rattling, but I still hear a knock (coming from the right side). It is primarily when the springs are compressed to the right side of the car (i.e. going up a driveway or reversing out of a driveway, making a turn, etc...)
I assumed at first that it was the swaybar, but my suspicion is that due to the stronger/wider swaybar, the chassis is causing the springs to compress more, therefore the spring (which, quick reminder, I have the TEIN prototypes in the rear) might possibly be knocking against something. What it's knocking against is beyond me. The knock (for frame of reference) is loud as somebody knocking on your trunk or using a tool to tap underneath the car. More specifically, it's one knock (not consecutive knocking).
I'd appreciate any help you guys could give me. Thanks.
drex
https://mbworld.org/forums/mercedes-tech-talk/75561-knocking-noises-my-c32-help.html
https://mbworld.org/forums/c32-amg-c55-amg-w203/75368-car-making-knocking-noises.html
My problem is that the noise only came into play when I got the swaybars. Now, when I make a sharp left or right turn, I can hear a knock (sounds like it's from the right side of the car). It happens when I'm backing out of an inclined driveway and turning the steering wheel (more consistent when I turn the wheel left while reversing out of a driveway).
Anybody have any recommendations on this?
