Front Seats
Old Oct 11, 2007 | 12:46 PM
Jkw's Avatar
Jkw
2004.5 C 230
Question Front Seats
I have a 2004 c230.
Can the front seat be swapped Driver to Passenger?
I know moving the whole seat wouldn't work because of the left/right configuration,
But what about the cushions?
Is it a DIY type of job or would I need a professional.
I ask because the driver side is getting worn and the passenger side still kooks new.
Old Oct 11, 2007 | 01:02 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i don't think u can, but not 100% sure....
Old Oct 11, 2007 | 01:55 PM
jedcred's Avatar
'04 Mars Red C230K Sport Coupe (not Coup-EH)
Do you have fully manual, partially power, or full power seats? If fully manual, no, since the holes for the back adjust knob won't line up.
Old Oct 13, 2007 | 06:22 PM
Jkw's Avatar
Jkw
2004.5 C 230
partially power,
can it be done?
Old Oct 15, 2007 | 04:43 PM
Jkw's Avatar
Jkw
2004.5 C 230
Any Ideas?
Jkw
Old Oct 15, 2007 | 04:55 PM
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
If its just the lower cusion you can swap those by removing it from the frame and swaping it. There are two plastic brackets that you will want to purchase from your parts department that will most likely need to replace in the process because they break when you remove them. The back might work to but with a little more work. You could swap the cover on that.
Old Oct 15, 2007 | 06:04 PM
California's Avatar
C350 '12
Depending on how bad the seat looks, an upholsterer could do it cheap. I owned the 450/380/560SL MB convertibles for years and the driver's seat had a congenital defect -- they would all get rubbed the wrong way and eventually the upholstery would wear out on the side. An upholsterer fixed it for like 100 bucks. I'd figure that out before I fooled around with your seats for safety's sake.
Old Oct 16, 2007 | 10:22 AM
Jkw's Avatar
Jkw
2004.5 C 230
Thanks guys, I'll let you know how it turns out.
