Quick Question About Side Mirrors
Old Nov 2, 2002 | 04:54 AM
brabusk8's Avatar
C320 , Audi A4, S500, Nissan Elegrand, Honda Jazz, Lexus RX 300
I'm having problem with my 2003 c320 left hand side mirrors. When I switch the gear to REVERSE, both side mirrors will adjust automatically so that I can see the surface of the ground ya? However, only the rigth side of my mirrors perform this function. Mine is a Canada car, therefore the steer wheel is at the left. And also the rigth side mirrrors printed "OBJECTS IN THE MIRRORS ARE CLOSER THAN THEY APPEAR." but the left hand side mirror do not say that. I really need some tech. help because this is my first Mercedes Benz. Thank you so much.
Old Nov 2, 2002 | 05:16 AM
JeT's Avatar
JeT
It sounds like your memory function is not set properly. You will need to look at your manual and learn how to set it properly. Actually, only the one side should do it...you only need the right side to go down because usually you are reverse parking on that side.
Old Nov 2, 2002 | 08:46 AM
NANA's Avatar
C230K Manny, Albaster White/Oyster Leather/C1/C5/C7/CD
C class will adjust only the right side mirror not the driver side.
Old Nov 2, 2002 | 09:04 AM
MB-BOB's Avatar
Admin Alumni
See Garage
NANA is correct. The tilt-down feature only works on the right-side mirror. The User's Manual reveals all.
Old Nov 2, 2002 | 09:31 AM
Mercedes's Avatar
2003 C230K
Yup on the right. And also if it ever quits working, make sure the right side mirror button is pressed, or it wont work
Old Nov 2, 2002 | 01:25 PM
antonio's Avatar
2002 C240 Classic
is this a special option with c classes or standard? im sure i don't have this feature.
Old Nov 2, 2002 | 01:37 PM
Mercedes's Avatar
2003 C230K
I think it was part of the C1 or the C5 package for the coupes. I think it comes standarad on all coupes im not sure. But i know mines comes with it.
I dont know about the sedans
JeT's Avatar
JeT
its part of the memory option.
Old Nov 2, 2002 | 01:49 PM
mdp c230k's Avatar
2002 c230k
It is not standard on coupes, you need the memory seat option.
Old Nov 2, 2002 | 02:47 PM
Mach430's Avatar
And on the CLK (probably applies to C as well), you need to have the mirror set to the passenger position. The driver's position will disable it.
Old Nov 3, 2002 | 05:18 AM
brabusk8's Avatar
Thank You people. Now I know a little bit more about my car.
Thank you.
