Bridgestone Potenza S-03 Pole Position
Location: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
For all;
I know this is a good tire; my question is, has anyone used them on a 19 x 9.5 inch wheel? If so, did you go with the 255 or the 275? If you went with the 275, what is the offset of your wheel?
btw, what is the proper toe settings for the rear? I just went through a set of Nitto 555's in 20k miles, and probably could of gone 6k more of it wasn't for the extreme inside wearing so much.
Re: Bridgestone Potenza S-03 Pole Position
Originally posted by CHATMANR
For all;
For all;
'01 C320 SS
I figured as much, so I went with the SP9000, 265's. Hopefully they won't larger than the Nitto 555's that I had.
