CEL on '03 C230k coupe need help with solving issue
Old Mar 22, 2008 | 07:32 PM
HarbortownC230's Avatar
2003 C230 Coupe
I was hoping someone could help me out on a problem I'm having. I have '03 C230k coupe w/75,000 miles on it. Have a check engine light issue I cannot get solved. There has been no change in the behavior of the car since the light came on. Took it to local shop and the shop said they were getting codes P201c/P2038/P2058 on the way to shop stopped @ Autozone, their scanner said code P0172. Shop changed out downstream O2 sensor, but did not fix problem. They finally gave up on trying to figure out problem and refunded my money. Hoping that one of you out here may have had this issue to help shed some light on it. Any input would be great, thanks in advance for any help
Old Mar 22, 2008 | 08:49 PM
Kristen's Avatar
C-class
Check your cam sensors first:
https://mbworld.org/forums/c-class-w203/226338-m271-leaking-cam-sensors.html
Old Mar 22, 2008 | 08:56 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Same problem I had. Leaking cam sensors fouled the wiring harness.
Not a good situation. Get it checked out ASAP, maybe you can save the ECUs.
Old Mar 23, 2008 | 10:58 AM
aolsen's Avatar
2013 S550, CLS500, ‘03 SL500, “92 190E Sportline
Take it to the dealer...There's a hose recall, they will fix it free of charge.
Old Mar 25, 2008 | 05:25 PM
HeirKranz's Avatar
C230k coupe 500sec convertible
can someone please post the tsb # or the picture of the PCV tube in a diagram or picture form for the sake of all on this site please---I think I know where it is at and needs a clamp but --someone please show a picture of it!!!
Old Mar 26, 2008 | 08:18 AM
HeirKranz's Avatar
bump??
Old Mar 26, 2008 | 12:12 PM
dmatre's Avatar
https://mbworld.org/forums/showthrea...&highlight=pcv
