Removing the steering wheel
Old Jun 16, 2008 | 10:33 PM
mbhackie's Avatar
02 C240 Black
I am aware it is always normally safe practice to disconnect the battery before removing airbags but do I reallly have to do it when taking the steering wheel bag out. (going to replace turn signal switch) I just want to avoid all the bs of disconnecting the battery... setting dtcs/losing memroy settings/risking the sam and I know putting a voltage regulator on it will defeat the purpose.
Old Jun 16, 2008 | 10:50 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Per Bif powell “…Disconnecting the airbag and reconnecting it is fine as long as the key is out of the ignition. As paranoid as I am, I didn't disconnect the negative battery lead as recommended by my shop, but I did establish visual contact with my keys at key moments in the procedure…” from his thread..https://mbworld.org/forums/c-class-w203/139782-w203-steering-wheel-swap-how.html
My turn signal switch is too funky. Would you kindly share a DIY of your procedure? TIA.
Old Jun 16, 2008 | 10:58 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
just don't put the key in the ignition when you remove the airbag. otherwise you will get a SRS airbag warning only the dealership can clear.
Old Jun 16, 2008 | 10:59 PM
kcheng86's Avatar
03 c320
i think you should be fine, when I switched out my steering wheel, i did not disconnect my battery
Old Jun 16, 2008 | 11:36 PM
Mu9enx's Avatar
01' C32o
yeah, just don't put your key in when you d/c the airbag.
Old Jun 16, 2008 | 11:48 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by splinter
..My turn signal switch is too funky. Would you kindly share a DIY of your procedure? TIA.
Same here. If it's not too hard to get to I'd like to remove/clean/lube the stalk.
Old Jun 16, 2008 | 11:58 PM
walker203's Avatar
S55, C230
man I love this forum there's a DIY for everything
Old Jun 17, 2008 | 11:56 AM
mbhackie's Avatar
02 C240 Black
Thanks for all the replies! Now I just have to wait for my new stock to come in.
