View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
Old Mar 18, 2006 | 08:40 PM
  #1401
jac1502's Avatar
2017 E550 Coupe
nitto 555 265/30/19
I have found where it is rubbing it is a small potion of sheet metal where the plastic bumper meets metal. I can easily grind it down but I am worries about heat from grinding hurting my paint. Anyone done this? I figure if I go really slow it should be ok.
Old Mar 18, 2006 | 08:45 PM
  #1402
sdsilverm3's Avatar
Originally Posted by jac1502
nitto 555 265/30/19
If it's just the metal tab that sticks out all you have to do is hammer that upwards.
Old Mar 18, 2006 | 08:46 PM
  #1403
Kenzmbz's Avatar
Originally Posted by FrankW
he had 19" mono VI powder coated and sold it. he's saving up for some 8-series HREs.
Ok Hre 8 series will also seal the deal. Cant wait to see it on the car !!
Old Mar 18, 2006 | 08:50 PM
  #1404
jac1502's Avatar
2017 E550 Coupe
Yeah that’s all it is I am just so worried about deforming the metal and causing a crease have others done that with no problems?
Old Mar 18, 2006 | 09:40 PM
  #1405
W0n6_3d4n's Avatar
C200K (w204)
Just hammer it . If u afraid of doing it, go to panel beater and ask someone to do it.
Old Mar 19, 2006 | 02:48 AM
  #1406
sdsilverm3's Avatar
I did it on my car and no problems here.
Old Mar 19, 2006 | 03:05 AM
  #1407
EV0LVE's Avatar
F10
I'm not sure if hammer will work, it might. I would STRONGLY recommend a rubber mallet along with a heat gun or blow dryer to give some flex on the paint.
goodluck
Old Mar 19, 2006 | 03:54 AM
  #1408
sdsilverm3's Avatar
goodluck
Good luck with the rubber mallet. I started with the mallet and gave up because it was doing nothing but bouncing. The hammer is what you need.
Old Mar 19, 2006 | 09:18 AM
  #1409
advans's Avatar
C55 ///AMG, 535xi
hmm since u get all that bouncing, maybe try a baseball bat no bouncing
Old Mar 19, 2006 | 01:20 PM
  #1410
TheBossman's Avatar
04 C230K-ss
alright alright so back on topic- aftermarket wheels...keep posting them up!
Old Mar 19, 2006 | 03:31 PM
  #1411
kiketron's Avatar
2004.5 C230K SS
Brand: Brabus Replica
Style: Monoblock VI
Color: Brilliant silver paint and polish lip
Offset: Front Spacers (don't know)
Tire: Toyo Proxes T1-S 235/35/19 265/30/19
Suspension: C230K 2004.5 Stock
Old Mar 19, 2006 | 05:41 PM
  #1412
jan ken po's Avatar
'05 SS Brillant Silver
Damn Kike..that **** is CLEAN & mean. That's stcok suspension??? looks lowered a tad. Either way, nice.
Old Mar 20, 2006 | 07:55 AM
  #1413
aecasasus's Avatar
'04 C230K SS
Anyone having problems after installing these wheels rubbing? I have just installed my rear springs (H&R) and I have some rubbing. Any ideas/ sugestions?
Thanks/Al
Old Mar 20, 2006 | 12:11 PM
  #1414
razorfish228's Avatar
BLACK 05 C230SS
Thanks/Al
Dam, I feel bad for you. I guess your running 265 tires aren't you?
You'll definitely rub if you dropped your car with H&R springs unless you raise it up a bit by changing the spring pad or rolling the fenders. If you don't want to do any of the above than sell your 265 tires and get 255 tires.
You'll probably get the same answer from anyone else so you decide.
Old Mar 20, 2006 | 12:32 PM
  #1415
aecasasus's Avatar
'04 C230K SS
Yes...They are 265's. I think it's time for me to go to the bodyshop. I will post some pictures on the other thread I got going to see the options. I would hate having to order two nes tires (55's) so I'll probably go to a bodyshop an/or get thicker spring pads.
Thanks/Al
Old Mar 20, 2006 | 01:17 PM
  #1416
Blake P's Avatar
'09 A4 S Line
If you haven't already had your fenders rolled, then I suggest you have that done ASAP. Assuming the rubbing is coming from the outside and not the inside, this should solve the problem.
Old Mar 20, 2006 | 02:21 PM
  #1417
aecasasus's Avatar
'04 C230K SS
Definitely not the outside. I think it just grabs on to the lip of the inside.
Old Mar 20, 2006 | 02:29 PM
  #1418
Blake P's Avatar
'09 A4 S Line
Just wanna make sure you understand what I mean by "outside" and "inside". I'm talking about the outside and inside of the tire, not the fender. Rubbing on the "outside" would mean the outer side of the tire is rubbing the fender, whereas rubbing on the "inside" would mean the inner side of the tire is rubbing the shock, spring, perch, or something else.
Old Mar 20, 2006 | 04:17 PM
  #1419
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
as usual when running on the 265's and lowered suspension setup the rear tire will rub on the plastic tabs from the rear bumper molding sticking out inside the bumper and the one area of carpet that's sticking out at the rear.
all you need to do is shave the tabs and trim out the carpet. rolling the actual quarter panel/fender's not needed unless you are seeing the tire side walls are actually being cut from contact.
Old Mar 20, 2006 | 05:08 PM
  #1420
aecasasus's Avatar
'04 C230K SS
Thanks FrankW!!! I'll try shaving those tabs a bit.
BTW... Thanks for the wheels. They look awesome. All I have to do now is work on the rubbing and the car is almost where I want it to be.
Thanks Again/Al
Old Mar 20, 2006 | 05:13 PM
  #1421
aecasasus's Avatar
'04 C230K SS
Sorry about that.
I'm so frustrated trying to figure this one out is not funny!!! I really cant see any marks or shaving anywhere and that's why I was thinking that it could be the insede of the fender. I'll try what Frank said...I won't loose anything for trying. Someone else also mentioned this to me. If not, I guess I'll end up rolling those fenders!!!
Wish me luck....I'll need it!!!
Thanks for your advise/Al
Old Mar 22, 2006 | 08:09 PM
  #1422
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
keep the chattin low...bump LOL
kiketron's not in US. most likely he has Euro spec suspension.
Old Mar 22, 2006 | 08:21 PM
  #1423
D_Star's Avatar
05 CLK55
any one tried putting 20's on their C class?? is it possible?? thnx
Old Mar 22, 2006 | 08:26 PM
  #1424
xxbenzc230kxx's Avatar
is not yet completed
yeh some one has tried... sinyo has tried it.. but it was a ***** to do.. had tons of modifications done... and still had slight rub..
Old Mar 23, 2006 | 08:30 AM
  #1425
aecasasus's Avatar
'04 C230K SS
Update....Rolled my fenders and work OK!!!
You have already rated this thread Rating: Thread Rating: 16 votes, 5.00 average.
