enigne stall at high rpm
Old Aug 8, 2008 | 12:12 AM
tranly98's Avatar
2003 C230 KOMPRESSOR SEDAN
Hi eveybody, I have a question. I have 2003 mercedes C230 kompressor sedan. I am getting an error for first cylinder misfire and manifold absolute pressure/barometric pressure circuit high input. Is it necessary to replace the ignition coil or what should i do from here? I just replace all 4 spark plugs, new air filter, 2 new O2 sensors, the up and down stream and a new mass air flow meter.
Thanks in advance for any advices.
Old Aug 8, 2008 | 08:57 AM
amanonfire's Avatar
W203
Have you fixed the $12 vacuum hose, or the cam sensor leak?
Old Aug 9, 2008 | 01:47 AM
tranly98's Avatar
yes, the $12 hose was changed by the dealer about a year ago. I looked at the cam sensors and thery were fine and not much oil mark on them. I just bought another hose ($15, the price's gone up). I try to change the hose and the fuel filter again this weekend. I hope the problem would go away.
Old Aug 9, 2008 | 09:08 AM
amanonfire's Avatar
W203
Alternatively it could be your cat, a clogged cat causes the engine to stutter at high rpm
Old Aug 9, 2008 | 10:11 AM
magnus203's Avatar
CL203, W211
Old Aug 9, 2008 | 10:41 AM
tranly98's Avatar
last time. I scanned the car and no error code show up relate to the cat.
Old Aug 9, 2008 | 11:50 AM
magnus203's Avatar
CL203, W211
Beware, scanners and diagnostic computers can only read black and white, they have no brain. They can sometimes throw red herrings into a diagnosis.
Old Aug 9, 2008 | 02:09 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
I think AMG-Jerry had this issue on his c32, but his was bad enough where car would throw a CEL at him.
Good luck.
Old Aug 10, 2008 | 12:01 AM
tranly98's Avatar
Do you know anything about "Reverse Inhibit Control Circuit Malfunction" (code p0410 ). How can you test there is leaking vacuum hose?
Old Aug 10, 2008 | 07:40 PM
DRAD-81's Avatar
2005 Obsidian Black C180 Kompressor - Elegance with Sports Pack
What RPM is this happening at? You say "enigne stall at high rpm" are you hitting the rev limiter?
Some cars mis fire when the car hits the rev limiter
Old Aug 11, 2008 | 01:05 PM
Buellwinkle's Avatar
The 2003 C230K had a minor problem with the head design. Replace with new design heads fixes the problem. It mostly manifests itself as a misfire in a cylinder that won't go away and it's due to excessive carbon buildup on the valves. Figure $1,500 for a new head and about 12 hours labor.
Old Aug 11, 2008 | 02:30 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
And usually that causes a misfire CEL.
But...it had to be more than like 20 misfires out of 600 to throw the code, so
I've also had the experience of getting misfires and NOT getting a code, usually at the onset of a coil pack failure, which quickly gets worse.
