Wow Check engine light With Pix WITH CODES
Well i was driving up a hill and i gave my car gas a lot i should say. And the car seem to have like half the power.. And i look down and it says check engine. I was driving the car home and the car just didn't seem to have the power like it use to at all. Car sounds weird now.
What do i do???? |
How many miles on the car? Perhaps the catalytic converter has collapsed
Originally Posted by krisv420
(Post 3031367)
What do i do???? |
79800
Anyone know a good place in socal? To take the car? |
I see you're in Oceanside. I've had very good service from MB of Escondido. It's not too far from you. One of their perks is they provide a loaner vehicle (MB C-class) with all service, regardless of if you purchased from them or not (Hoehn in Carlsbad only gives MB if you purchased from them). They charge about $20, but it includes about 1/2 tank of gas, so not a bad deal.
Originally Posted by ffejalink
(Post 3031490)
I also saw this. http://www.harborfreight.com/cpi/cta...emnumber=94169
If you just want to pull the codes, go to Autozone and rent a scanner. They will charge you full price to borrow it, then credit full price back to you when you return it. When they've been slow, I've also been able to talk them into letting me just use it in the parking lot (I live in a small town where everone knows everyone).
Cars are smart enough these days that if the engine starts to overheat or something else is going on, the computer will put the vehicle into 'limp mode'. You might start it up again after things have cooled down to see if there's still a CEL (if not, the code should still be stored). Of course, there had to be a problem to trigger this event in the first place ... but you could just be low on coolant or oil. Good Luck!! |
...or just BUY a scanner.
Sounds like a bad coil pack. |
Well im not gonna go to work. Gonna see what i can get done today with the car. Gonna go and start it in 2 hours and see what happens.
Its just odd i was low on gas so i go to the station. Fill up a half a tank go drive for 1 mile and now this happened. |
Was your fuel tank full or almost empty? Maybe went to limp mode starving for fuel? Just a thought and something for you to look into or discard. Hope you find the problem soon...
Originally Posted by aecasasus
(Post 3032143)
(Post 3032599)
The light was about to come on . I was driving pretty slow to the gas station everything was fine with the car before hand didn't have one issue driving there. It seems like after i filled up with gas something happened.. gonna go start the car now i fell back asleep lol
Hope it works! Let us know how it goes and if that does the trick... |
(Post 3032607)
Oh another odd thing is when i go to check my oil level for my car on the computer.. It says perf mant on time now. it will not check the level |
(Post 3032654)
No the car sounds like ****.. It runs and when i give it gas sounds like really fast ticking sounds when i accelerate :eek: Im stuck the car just doesn't sound good to drive. Yesterday when i was driving it home the temps started to go up a little. Oh and i saw two bmws crash in front of me good thing i was only driving 30 MPH a cute 330 and a nice 545. But anyways im thinking about driving the stupid thing to get the codes read and go from there.? Oh remember the car only has half the power =(
(Post 3032654)
Originally Posted by PA_Pete
(Post 3033057)
Mine says this too.
a. It won't do it with the engine cold. b. It won't it with the engine running c. It won't do it right after the engine is shut off. You have to have had the engine running, and then shut it off for a few minutes. If it says perf serv on time, you need to wait a little longer and do it again. |
(Post 3032599)
Originally Posted by Saprissa
(Post 3033475)
what kind of fuel did you put in there ?
After finding out how much it would be for the dealer to check whats wrong with my car i think ill just let it sit in my driveway for a few days. I just don't care.. |
Took of the air box on the car on the left side of the motor.. i was looking at spark plug caps and i go down to touch one of the caps and there is fresh OIL on two of the caps.
Motor picture http://img511.imageshack.us/img511/971/1000714up0.jpg Leaking oil =*( http://img231.imageshack.us/img231/6228/1000698zi7.jpg More Leaking http://img231.imageshack.us/img231/92/1000707nm1.jpg Closer look on plug http://img241.imageshack.us/img241/7492/1000712fo0.jpg :eek: http://img231.imageshack.us/img231/7198/1000718ca1.jpg |
Not good!! I would NOT try and start this car again. Ticking noises are typically a sign of something potentially serious. I have a sick feeling just reading this post and looking at the pics..Keep us posted!
Originally Posted by Brad460
(Post 3033711)
I'm wondering if the oil on the spark plug wires isn't having some sort of affect on spark to those particular cylinders. That is of coures if the oil is on the wire down where it plugs onto the spark plug itself. Oil sitting on a wire loom isn't going to affect anything, but if its in where connections are being made, that may be a problem. I think your first ordeal should be to find out where the oil is coming from and fix that first. That and check your oil level (due to the ticking noise you say you hear). Good luck. Also, def. let us know what you find, I have the identical car, so it maybe something I or other people may need to look out for.
(Post 3034624)
Again, it could as well be a bad coil (like some members mentioned)or cable due to the oil, dropping a cylinder ir two so...troubleshoot first, invest in repairs later. Just my $.02 |
(Post 3034644)
he might have a bigger problem (like a bent rod) that needs to be found first. It might not be worth spending the money fixing the oil leak if the engine is not good. I beleive he needs to find out where the knocking sound and loss of power is before he starts fixing anything else...
Just my $.02 |
