man wtf wrong with my car now?
Old Dec 24, 2008 | 01:24 PM
Benzino's Avatar
03 c230
k, here is the deal........
I was merging on the fwy, not mashing out, but simply merging and the car all of a sudden had no real power, the car went smoothly, but no power. When I came to a stop I expected the car to shake, but it didnt. No, check light. I turned off my car and the car ran fine, whats going on with it?
Old Dec 24, 2008 | 01:27 PM
billbugger's Avatar
C230 Kompressor Sport Sedan
Does yours have a SC? If your running smoothly, but with no power, maybe it bit the dust or something.
Old Dec 24, 2008 | 01:37 PM
beachC230K's Avatar
C230k coupe
don't worry
Something similar happened to me. I accidently shifted to 6th instead of 4th. When I tried to accelerate moments later... no power. Seems it didn't like being "lugged" like that. It has not happened since.
If you turned off the ignition and restarted it and have not experienced loss of power again, then don't worry too much. (Crossing yor fingers might help too.)
Old Dec 24, 2008 | 01:45 PM
Glyn M Ruck's Avatar
Super Moderator
The car likely went into limp home mode. Restarting reboots the ECU, TCU etc. Sticking the car into reverse while moving forward can trigger this. Obviously not the case here.
Could well be a one off event. Check all fluid levels including auto if it's auto & just watch it for a while. I've had this happen once 30,000 Kms ago never to return.
Old Dec 24, 2008 | 02:34 PM
billbugger's Avatar
by bit the dust, i mean loosing compression.
Old Dec 24, 2008 | 05:14 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Coil pack? Thats a pretty good description of what happens when they're on the way out. Turning the engine on and off resets it,
for a while till it's a solid failure.
Whats the CEL code? If it's a misfire, swap the coil packs between cylinders and see if it goes with the CP.
Or...it could be much worse...people seem to have bad problems with that M271 engine. Valves and such.
Old Dec 25, 2008 | 12:10 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
loose coil packs
throttle position sensor
temporary mental retardation of ECU....
Old Dec 25, 2008 | 02:35 PM
drb930's Avatar
2005 C230 Sport Coupe
temporary mental retardation of ECU....[/QUOTE]
Too funny!
Old Dec 30, 2008 | 01:11 AM
Benzino's Avatar
03 c230
Ya the car is retarded for sure. When my car goes in limp mode it does not vibrate/ shake like it has done before. My car idles really smooth. wtf is the problem. I really dont know what to look for. Hey Diamond Bar do you think you can help me check out my car. Thanks.
Old Dec 31, 2008 | 11:22 AM
tonydr00's Avatar
2002 CLK 430
coil pack?
Old Jan 14, 2009 | 06:30 AM
LorinserCClass's Avatar
The True OG Modded out W203
maybe it's 'da ghetto wheels' you have on the whip homie j/k glad your car's at least still running benzino!
Old Jan 14, 2009 | 07:34 PM
jobela's Avatar
Station c200CDi - 2003
Check MAP sensor, it's cheap to buy 1 just to check. After swapping for a new one, you must reset the car or it won't recognyze the new sensor
