OBDii (On board diagnostic) - clear SRS error?
My education about the ODB is very small. To my understanding it can be used to clear CEL and read the codes.
Would anyone know if it would also clear the SRS error light?
-thanks
Answer: No - You would require something like the Snap On scanner. Cheaper to go to the dealer.
I hope you know the cause of the SRS error and it's something that you fixed, like disconnecting an SRS part temporarily. If the cause of the error remains, clearing it won't help you, it will pop right back up.
-key was in the ignition and turned to the first position
- i unplugged the seat control module under the passenger seat......
this is a documented cause here on this forum....
i am just trying to look for another option verses going to the stealer..
-thanks
charles
-thanks
charles
