drop in intake
Old Feb 15, 2009 | 10:39 AM
fazzaw203's Avatar
03 c320 4matic
drop in intake
i was panning on getting a K&N drop in air filter for my 03 c320 . does anybody have it ? is there any difference in sound/performance ? thanks
Old Feb 15, 2009 | 11:43 AM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
It will eventually ruin your maf. The oil on the filter bleeds through and gets all over ther crosshairs and generally makes a gummy mess internally. Stick with a good paper element and change regularly. It will provide all the air your motor can breath.
Old Feb 15, 2009 | 01:02 PM
BlackC280's Avatar
C280
Hhmmmm... interesting... anyone else had this issue? i was planning on buying one also. anyone else please chime in. maybe a voting toll would be good???
Old Feb 15, 2009 | 01:04 PM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
dont do K&N...
just get OEM ones and replace them twice a year or so
Old Feb 15, 2009 | 01:26 PM
BlackC280's Avatar
C280
Originally Posted by BlackLiquorish8
dont do K&N...
BlackLiquorish8 - hav u run into this problem as well??
Old Feb 15, 2009 | 06:37 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i've had k & N's for over a yr in my c32. Before that i've used them in my other cars with no problems. You won't notice much of a difference, except a slight increase in throttle response.
They do come a little over oil from the factory, just get a napkin and soak up the excess oil before you install them and it should be fine.
Old Feb 15, 2009 | 06:51 PM
TVT_DESIGN's Avatar
Former Vendor of MBWorld
Chrysler Crossfire
The only times there are ever any issues with the oil in KN filters is when owners decide to re oil their filters and don't do it properly.
We run KN filters in every car we tune and have for many, many years with 0 MAF issues. The amount of oil that would need to be on the filter would make it soggy to the touch. I've yet to see a KN filter from the factory with too much oil.
If you want some KNs we are a distributor, if you want OEM we have them as well.
Old Feb 15, 2009 | 08:15 PM
i havent really had any problems but when i did run K&N i found that my maf was oily... luckily i found out early and replace filters with stock. K&N doesnt really increase HP that much so for me i just use clean stock filters rather than fun K&N. i rather replace stock filters more often and find my car running better
Old Feb 15, 2009 | 09:10 PM
acr2001's Avatar
2012 C300 4Matic
Don't do it. You risk fowling things up with the oil. The aftermarket filters do not catch nearly as much dirt, and they have much less surface area than the OEM filters. While you might get a VERY small performance boost it's just not worth it. The stock filters are plenty large and not restrictive. Those who feel more power probably swapped dirty clogged stock filters for new K&N filters.
fazzaw203's Avatar
03 c320 4matic
i didnt expect any problems using K&N drop in filters nor any increase in HP. i just dont want get new OEM filter every few months. how bout Green filters ? same problems with MAF ?
Old Feb 15, 2009 | 09:26 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
K&N,been around for 40 yrs.Good enough for DTM racing-good enough for me.I've used them for 19 years,never a problem.As far as the mass air sensor contamination,read here : http://www.knfilters.com/faq.htm#27
Old Feb 15, 2009 | 09:32 PM
BlackC280's Avatar
C280
40 Years in Business, I'm sure they know what they're talk'n about. Time to order mine.
Old Feb 15, 2009 | 09:35 PM
advans's Avatar
C55 ///AMG, 535xi
I've dropped k&ns into my c55 recently, i hate it. the car actually feels that it breathes better with the stock filters than k&ns.
Old Feb 15, 2009 | 09:40 PM
acr2001's Avatar
2012 C300 4Matic
Makes sense to me, the stock air filters have far more surface area.
Old Feb 15, 2009 | 10:31 PM
advans's Avatar
C55 ///AMG, 535xi
it does.
the k&ns actually make the car feel a bit...sluggish.
Old Feb 15, 2009 | 11:38 PM
TemjinX2's Avatar
it probably won't really help the c320's but i remember c32used did a comparison with stock filters, green filters and the K & N's. Both green and K & N filters improved his quarter mile times on the c32. So they do help, just not a lot.
Old Feb 15, 2009 | 11:42 PM
TemjinX2's Avatar
here's c32used track times between there three different filters.
https://mbworld.org/forums/c32-amg-c...k-filters.html
Old Feb 16, 2009 | 06:11 PM
shivi1345's Avatar
MK IV .:R32
anybody use a BMC or Green filter?
Old Feb 16, 2009 | 07:31 PM
Ryanr317's Avatar
R129, XF Sportbrake, SC400
I've had them on mine for over two years with no issues.
Old Feb 16, 2009 | 07:51 PM
PA_Pete's Avatar
2001 C320
Your MAF sensor is going to get dirty or cause a CEL eventually, whether you are running K&N's or stock. Either way, Pick up some MAF Sensor cleaner and follow the directions on the can. This $7 cleaner has made my CEL go away and saved me $430 (dealer quote to replace MAF). Oh yeah, it also got my buddies F-350 idling and running right too.
Old Feb 16, 2009 | 10:33 PM
advans's Avatar
C55 ///AMG, 535xi
I was reading on e60.net that these K&N/Green filters are great only for SC/TURBO motors.
I use to be pro K&N, but after i put in stock filters again, they felt way better! I had K&N in my C320 and green in my ML500. they were horrible.
I gave k&n another try with the C55, had them on for a day, hated it. now i'm using dirty stock filters.
Old Feb 16, 2009 | 10:46 PM
TemjinX2's Avatar
i would advise against t he green filters, they have a tendency to collapse.
Old Feb 17, 2009 | 10:16 AM
shawns2006C280's Avatar
2006 C280
I just go the dual K&N set up and love the performance haven't had it long enough to see an increase in gas mileage. I own a few show cars and even have a car that I take to the track, in all cases I have used K&N or similar performance intake and filter that need to be oiled, I have yet to have one single issue with MAF sensors or check engine lights. Now I wont say its not possible because anything is I would just suggest when you oil it yourself dont go crazy with the oil that is usually where the problems happen.
Old Feb 17, 2009 | 10:30 AM
PA_Pete's Avatar
2001 C320
Good to know!
Old Feb 17, 2009 | 09:10 PM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
anyone use this on a c230k? i was actually recently thinking about making the switch!
