Need help to choose right ATF for 722.6 ATF3403 vs ATF 3353 vs ATF 4134
I said DO NOT use Dexron 3 or 6 in the 722.6 transmission. It is NOT approved by Mercedes Benz.
Use only products meeting Benz 236.10 or 236.12 approval.
Please buy the correct fluid from your Mercedes Benz dealer for your 722.6 transmission
If your dealer says you can use Dexron 3 or 6 they are WRONG! (NOT CORRECT)
it is strange because the nag it mounts dexron3 of of varied marks... agip,castrol,mobil1,valvoline etc..
I do not understand because dexron6 is not suitable.
attention, the technical cards of the dexron6 say that it can replace the dexron3 dearly.I am confused...
my car uses: "Castrol TQ-DIII or TQ-D, Agip DexronIII or ATF II D , Tamoil ATF II D." -> here because I do not understand in order which reason cannot replace with dexron6
On top of it, Mercedes improved over the original specifications for 722.6 transmissions with the 236.10 first, and the 236.12 more recently.
So, the only oils recommended by Mercedes for your transmission are:
1. Mercedes Benz 236.10 ATF, sold at the dealers.
2. Fuchs Titan R134 ATF.
3. Shell R134 ATF.
There are no substitutes and no confusion about it. Forget Dexron 6.
Ciao, JV.
is the new long life 236.14 product. Example Fuchs Titan 4134
236.14 products were developed for longer life & more consistent gear change on the NAG2 722.9 7G - 7 speed auto transmission. The 234.14 product is backward compatible.
BTW - Love Italy. I could happily retire in Tuscany
Ciao
I will use oil 236,14.
Fuchs Titan 4,134 I will find on ebay? know other easily available mark oil 236.14 on ebay ? other question: you know the procedure of adaptation the torque converter of to gearbox ???
thaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaanks!!!!!!!!!!! !!!!
ot: Italy good
They say to use the newer fluid but still make the old one very odd. I can't wait to get my transmission flushed again but at 152k i want to keep it going.
The new fluid is longer life/has greater oxidation stability & maintains shift quality for longer. It still requires to be changed at the same interval but will behave better & more consistently over it's lifespan.
I do have 1.5 qts leftover if anyone wants it.
Not only does all of this worrie me, it seems as though I will need to get that fluid replaced.
The dilemma now would bewhether after draining it will leave too much of the non-listed (non approved) oil and if there is any danger of it?
Am I correct that my 04' e320 4matic W has the 722.6 designation for the AT?
This was the fist AT fluid change - at 55k miles.
Thanks again.
I want to do a transmission FULL flush & filter change in my 2004 C230 Kompressor.
This car IS in fact a 5-speed automatic, correct?
Is there a cooler line, such as a return line I can tap into? I ask, because I did this on my Ford pickup truck. I just attached a fish-tank clear-acrylic tube to the RETURN line, turned on the truck, and kept adding fluid to the tranny. Had a friend in the driver's seat go through all the gears, P, N, D, R, etc. Of course we did this after changing to a new filter.
Is there a way to do this method on my car?
Also, what fluid is the recommended fluid for the C230 Kompressor?
This thread has a lot of information, and quite frankly I'm overwhelmed.
What quantity does this vehicle take, and where can I view the level? (Since there's no dipstick?!)
Thanks in advance, I really appreciate any and all help.
-Matt
-Matt
See method below & splinter & C230 Sports Coup all things transmission threads for practical tips on level setting.
https://mbworld.org/forums/attachmen...0flush1-1-.pdf
https://mbworld.org/forums/attachmen...0flush2-1-.pdf
Go Benz 2006 & type in "fluid" - it does not come up under transmission.
You have a 2004 with 5 speed correct?
If so than this is the correct stuff yes?
NAG 1 was the first designation of the 722.6 in it's many initial forms. It has progressed from there.
All I am suggesting is that people use the newer high performance fluid as you do in your old banger. There are benefits in doing so.
