Whats the draw?
Yet again the C-Class has given me problems
Anyways, my car has a draw somewhere, Ive already replaced both seat modules, the COMMAND system was also drawing, so we did a relay switch on that.
I've got a fluctuating draw, from 3-1amps at any given time, so we are assuming that the computers are doing something, hence the fluctuating draw.
Now my mechanic has tried everything and he says that Mercedes will hook up the car and instantly tell me where the draw is....but the stealership will charge a redic. diagnosis fee and i've already poured so much money into this...but I will do that as a last resort.
Anyways, mechanic thinks it COULD be the rear SAM...any ideas or suggestions as to what can be drawing my battery? The car works fine for two days when untouched but after the third it doesn't crank at all.
Im really really worried that its the rear SAM
Anyways, if i start the car every day, or every other day it still will work. As a side note, I disconnected my driver side seat module, this is a replaced one (the left one has been disconnected ever since it was drawing, never bothered to replace it)
After my car was up and running, I plugged the two cables under my seat back into the module and the seat still isn't working. Did I blow a fuse cause I did it while the car was running? If so, which fuse is it plz?
My mechanic told me maybe its because the battery was being drained to 0 so much that everytime I restarted the car the SAM module rebooted too and it takes time for it to recognize something that isn't there, or something along those lines. So I disconnected the negative terminal of car and reconnected it after 10 minutes, started the car, and the seat still wont work.
Any ideas? Thanks for your help so far.
