W203.045 TPS FAILURE?
Rating: Thread Rating: 3 votes, 5.00 average.
Old 05-12-2009, 05:02 AM
gusvlachos's Avatar
w203.045, also there are, 2 Racing Minis ,1 Lotus elan+2,1 Hyundai getz 1.6 .Some other passed.
Hi the all,
After rear SAM replaced,new problem in the car,(nothing to do with SAM) .When you try to accelerate,no instant power,power comes always after 5-6 sec ,and like a limp mode,or like no boost from kompressor .Undriveble!This is happening 8-9 times to 10 .But once to 10 , work perfect.EOBD tester kept codes P0101,P0102,P0301,which droves to MAF( low voltage,no:1 missfire..).No TPS error code .MAF replaced with a brand new equivelant, from LOWE Germany(MAF Hot film specialist. Before this, an unpluged OE MAF test applied, and the problem remained the same.After the new one, the engine rev perfect for a minute ,soon after the same problems.So MAF is not the problem.Except an oily cam magnet connector(cleaned),all other sensors seems ok,with a first look. Any suggestion is wellcome, before i go deeper, and try to get a STAR diagnostic??!!.(Mercedes must offer a star tester for FREE,with a w203 sale!) The car has strictly,20k miles only since new,and this seems another weak point of w203 electronics.-
Thanks Gus
Old 05-12-2009, 06:03 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Please prepare and submit the TPS report using the new TPS report form,
in triplicate.
And use the red stapler to collate the copies.
FYI- A New SAM requires programming...go to a qualified indy guy with SDS.
Old 05-12-2009, 06:18 PM
Super Moderator
Glyn M Ruck's Avatar
I've never told anyone to STFF - But it's getting VERY close - How many TPS threads are active right NOW
Old 05-13-2009, 05:04 AM
gusvlachos's Avatar
in triplicate.
Thanks a lot for the reply, SAM is programmed.I 'll send the report soon.
Gus
Old 05-13-2009, 05:26 AM
gusvlachos's Avatar
Who told you, that i didn't check all previous posts about tps issues,and many more,smart guy?!! As an oldy you are ,you had to learn ,that always we teach our selves, even after 30 years of experiance.So be patient and polite with new memders,more open eyes & ears , less open mouth,i've learn.
Friendly, Gus Vlachos
P.S It is very easy for me also, to told someone to STFF.
Old 05-13-2009, 12:07 PM
Super Moderator
Sorry - yes - we do all have to learn. I've never not helped anyone & never told someone to STFF - I would recommend you join one of the 4 TPS threads that have been started in the last week rather than start new threads. Then when people search it's easy to find the info in one place. We will get the mods to put all these threads together like the Tyre & Wheel thread. See sticky by Drex above - Our mods try really hard to keep this forum workable. Good luck - Hope we can help.
Old 05-13-2009, 01:49 PM
Bad TPS will supposedly result in a P0120 OBD2 code.
Old 05-14-2009, 02:46 AM
gusvlachos's Avatar
[quote=C230 Sport Coup;3521356]Bad TPS will supposedly result in a P0120 OBD2 code.[/quote
Exactly ''C230 SPORT COUPE'',
but looking in many European & Usa MB forums a week ago,i find out that a lot of cases with similar problems with my w203,resolved ( some ), by replacing the TPS (in official MB services), without a P0120, 1....code putted. I bought that car recently, i love it,and i want to keep it, till the end. Of course,i realise,these are problems,specially for the early's w203.But trying to eliminate repair costs & time,allthough i'm an old experianced automechanic in British cars,MB forums like yours is very helpfull for me and others,as far as MB electronics considered.Even a pro, can't do accurate prediction without the proper s/w(not generic),allthough he know how.You see MB has ''sealed the softwares'',and is not very easy to find it,(at least not cheap for an MB owner), in comparison with other German carmakers .So diagramms & s/wares like Mr Rucks's, are extremely helpfull.
Thanks Gus.-
P.S When i find time, I'll try the TPS voltage tests ,and i'll let you know.Sorry for my poor English grammar, i'm foreinger.-
Old 05-14-2009, 03:01 AM
gusvlachos's Avatar
Smile
OK Mr Ruck,
you have absolutely right for a workable forum, threads have to be organised ,because there are a lot of causes for any individual failure(therad).Soon, i'll be a retired mechanic as you,and i would love to have the time to share my mechanic & racing experiance to all, in this forum.-
Gus
Old 05-14-2009, 02:14 PM
There are carsoft knockoffs available that read additional errors that an OBD scanner won't.
Requires a PC though...and finding out what the codes mean...not so easy.
Do you have a laptop? If you've worked on British cars...well, like me, you're used to problems.
I cut my teeth on FIAT's.
And yes, the forum is a valuable resource.
What's s 203.045 anyway? Maybe update your profile so it shows what car you have and region of the world you live in on the left side.
[quote=gusvlachos;3522774]
Thanks Gus.-
Old 05-15-2009, 05:32 AM
gusvlachos's Avatar
[quote=C230 Sport Coup;3523506]There are carsoft knockoffs available that read additional errors that an OBD scanner won't.
British car's problems you said ? he-he ....a lot! This time i try MB.-
I have a laptop.
Except early's Rover diagnostics,two PC OBD2 scanners(Auto Tap & Ilexa),i'm looking for a MB specialized software,but these i found are rather expencive(1450 euros approx.).Any recommedation wellcome.
You said british cars, you work for FIAT GROUP also? How long are you in car business?
Obvious W203 declair MB series ,the other 3 digits of VIN no,(e.g 045 or so..)gives all the details about your specific model, if you visit http://www.detali.ru/cat/oem_mb0.asp?TP=1 and choose the 3digits of your MB you 'll find all the details of the model(engine specifications,...everything),next if you type all your VIN you 'll find all the details, specialy of your own car.(options.....)
My profile now is updated.
Old 05-19-2009, 05:09 AM
gusvlachos's Avatar
[quote=gusvlachos;3525151]
I have a laptop.
After some TPS/tech informations, from MB/forums,i did the "hard" job ,and i fix the TPS problem costless and accurate.Interesters send PM.
The complete job 'll post soon,for DIY.Don't throw away the old TPS from early w203 ,90% are repairable.
Old 05-20-2009, 09:18 AM
gusvlachos's Avatar
TPS:FAILING,TESTING,REPAIRING
[quote=gusvlachos;3531927]
TPS: FAILING SYMPTOMS,TESTING,REPAIRING(the most)
Carried out on a w203 early model 06/2000(M111) TPS, with kickdown switch, 20k miles on. Probably applies to later's aswell, as other engines(M112,..),which use "hall effect" TPS sensors.
Applies to those members,who can't afford, or they don't want to pay high bills in MB dealers,and have some DIY skills. All others who can afford it, they haven't to worry,bother themselves,or spend time,
...,just pay!
SYMPTOMS:
1)Engine starts ok,idle ok.
2)Any time you press accel./pedal(..driving,or swifting gears,or idling ),no instant power,but comes after 3-5 secs delay , and ends in a limp mode or reduced power.(no kompressor boost/where available).
3)If you press slowly pedal,things are going little better,but ends with same undriveble way.
4)Once in a while or so,car may work perfect!!
This is the situation ,you have to reach,before proceed a TPS test.All others, who notice a rare power delay/loss,and after restarting the problem has gone ,they have the time . Soon or later will notice same symptoms, as TPS voltage setup fails.
ERROR CODES:
Some cases, put the correct TPS codes P0120,P0121.., other instead (many cases in the forums,aswell as mine) ,give MAF error codes,P0100,P0101,missfiring codes P0300,..thus driving to MAF replace (I try this also).There is an exlanation for it.(optional issue)
No matter if you erase the codes from the memo,after some driving circles,codes reoccur as stored or pending errors, in moderate revs.
So,in this point always proceed an unpluged MAF test.If the problem remain, replug your MAF ,it is OK,and proceed a TPS test, is the most suspicious.
TOOLS:
1) A reliable voltmeter/multimeter
2) A household battery supply of 5v,( or more volts, if using a variable resistor).
The target is: to obtain a testing voltage from the battery equals to the measurement w'll get later from theECU/ECM (N3/10 ME-SFI) voltage supply ,to TPS connector.(You can achive this using some old 1.5v,4.5v batts & doing compinations).The correct is, to use a variable resistor-is cheap.This is important to obtain accurate measures,from TPS Sensor later.
3) Two pieces of Φ:1,5mm wire, 1/2 meter long.
4) Two needles(pins),to put firmly in multimeter's leads with tape, to reach connector's narrow pins.
PROCEDURE:
1) Remove keys
2) Remove TPS assembly,as follow:
a)remove tap in the pedal base to see the holding nut.Undo nut,and raise a bit the pedal to give room.
b)Unplug beneath pedal the kickdown switch(k/S) connector.Use your fingers, or a bended long iron nail (not anything steel/scr-driver!!) , and a mirror to see what you doing,(if K/S,exists-till 4/2002).
c)Unplug the TPS 6pin connector in the right side,now you are ready to get the sensor off.
d)By moving it left/right(to avoid vertical plastic) and pulling towards you,and then turning upwards you take it out in the bench.It is easy.But if you find difficulty,release plastic panel (3torxs) to make some
room,taking care to bonnet release knob & diagnostic socket (LHD)].
WARNING:
Before work on any electronic device's connector pins,always degauss your self,by touching a good ground (house water tubes..),to prevent static sparks,are lethal it.
N3/10 ME-SFI(ECU), OUTPUT VOLTAGE TEST TO TPS:
For this test,turn ignition on(cluster lamps on/II keys position),after finish take keys out.
In the unpluged TPS connector in the MBfloor,measure voltages at pins 1(+) & 6(ground),then at 1(+) & 3(ground)..These has to be between (4.75v-5.25v) limit.If so, this says that grounds is ok in ECU, and
Signals 1&2 (S1)&(S2), of sensor is supplied with correct votage.Now NOTE voltage (e.g 5.010v).This volt value have to be achived in the test battery for accurate setup.We are ready now for TPS test. AVOID accidental short cirquits during measures. Do CAREFULLY, and everything will work.
TPS INFORMATION:
As i found out dealing with this problem,the sensor uses the "hall effect" principle in order to avoid rapid use wear, (in comparison with old type variable resistors sensors),by no friction between moving parts.This is true for 1/3,2/3,3/3 sensor's positions,but not in the idle position.And i guess this is the weak point of TPS.After so many times of pressing and releasing the pedal,as time goes by (mostly from sudden releases),the pedal & sensor has to return back to its stop rather vigorusly, (with help from a rather hard returning spring),driving this to change its original stop position ,resulting TPS's idle voltage setup, out of calibration.Then all above symptoms occurs. With this in mind,i gave the follow easy
solution, (no TPS dismalting required).
PRE-REPAIR TPS TESTS:
Hold STEADY the TPS in the bench, (use carpender's catcher tool or so..) .
TPS VOLTAGE TEST:
Prepair the test battery with the CORRECT " previous noted" voltage of ECU output measure, (e.g 5,010v),and bring it near TPS.This voltage ECU is recognised, as a volt refering value for setups.
Take one piece of wire, and bare one side for connection to batt.(+) ,cut the other side clearly, and insert a needle to make a room, prior to insert it down with care, to male pin(1) of TPS connector.This is the (+) TPS feed for test.You don't have to move it again, before test is completed.
Take the other wire ,bare one end for connection to batt (-),the other end bare it about 3mm and twist it firmly then bend it back, and make a needle room, prior to insert it in male pin(3) , of connector.This is (-) feeding for S2 (low signal),& S1 (high signal) soon after.
To measure S2 signal,just put voltometers leads to touch, 3mm bare twisted wire in pin(3) (black lead), and the (red lead) in pin(4), the value you get is idle S2 signal,and have to be over 0,100v (in faulty TPS goes around 0,050v-0,080v). Rememper always to make S2 signal test first, because S2 gets lower faulty values, than S1 do. AVOID accidental s/c!
To measure S1 signal just remove the 3mm bare wire from pin(3) to pin(6), and measure value between pin(6)(black lead) and pin(5)(red lead),the value is the idle S1 signal, and have to be over 0,200v,
(in faulty TPS goes around 0,150v-0,170v).
THESE LOW VOLT IDLE MEASURES ARE THE CAUSE ,THAT PRODUCE POWER DELAY/LOSS BY GIVING WRONG SETUP INFORMATION TO ECU.
You can check also S1 & S2 volt values, at 1/3,2/3,3/3 & K/S positions (highest volt value). Maximum voltage have to be <4,990v ,but i'm guess you'll find all ok. Also check, that S1 values are approx. double than S2 are,in each pedal position measure. (Ignore pin2).
Follow this pins sequence measures (accelerator error2.pdf https://mbworld.org/forums/c-class-w...ml#post2161186,accelerator error2.pdf, ),though some diagramms give wrong volt pins testing.
TPS REPAIRING:
WHAT WE TRY to achive by following trick,are: a) To get a S2 value at idle position, around ( 0,140v min - 0,180v max ),thus the S1 values will give somehow (0,320v - 0,380v max ) .
You 'll notise that daviation (dV) in S1,S2 signals, is over 8% than specification give, (actually is up to 13% approx),but ignore it,nothing you can do. No big problem . Mine reach over 32% , and no error code putted.In volt setup for ECU,is far important (hi-lo) S1,S2 idle volt limits,than the daviation}.The equation is dV% = (S1/S2x2-1)x100. Any way don't over pass maximums,because idle 'll rev to 1500 rpm .
b) To make a good feel, timelast pedal stop.
THE TRICK:
Is simple ,raise the TPS cover by unclicking side clicks & remove it.
Insert (not permanently) two plastic pieces of PVC (3,0-3,2mm panel's thick) till to TPS surface (for free TPS cover close), in the corners at inner sides of TPS ,where the pedal rest and leaves an approx. 3mm-4mm gaps (L-R gaps are not symmetric),(diagramm to be attached,red arrows).
The starting dimensions of plastic pieces, are approx.: LEFT SIDE 5,2X20,0 mm ,RIGHT SIDE 4,2X9,0 mm(no much room for longer insert).
Proceed now in TPS volt testing as described above,and do any changes to PVC width (using a grin-
der),prior to obtain desirable S2 value(0,140v-0,180vmax).Then check S1 value. If all are OK,go to
next final step.
FINAL STEP-WARNINGS:
A)The PVC pieces must have nice square cuts ,be CLEAN,and seat well in CLEAN TPS corners.
B)The moving pedal's stop,has to touch both PVC pieces simultaneously ,when returns.
C)At final stage,these pieces has to be SECURE for falling down,to AVOID troubles.
After glouing (i use UHU universal,is more elastic) , put a TAILORED STEEL CLIP for chassis holds,to secure for sure the pieces with TPS walls,and use a hair drier for awhile to dry glou,prior to put a second overlay .During heating, force pedal backward to make a good stop seat easier, between PVC pieces & pedal's stop.
AVOID glou, to stop points. AVOID/PROTECT sensor's overheating.
D)Use quality materials and your skill, to make a quality job.
E)The pedal must move freely to it's travel.After all leave it for some hours to dry,and..
F)Read well all above,and if you think your skills are not enough,DON'T do.
As a final touch, before close TPS cover,lubricate with silicone ,the two plastic axles of pedal motion.
Now recheck pedal's free travel,and feel how good it stops ,instead of previous slugish one,(it'll last long more , than it's original fiting).
Put TPS back ,in reverse action, make a TPS RESETTING ,(https://mbworld.org/forums/c-class-w...libration.html),( NOT by disconnecting battery ), and go for a ride to teach your ECU.The car will kill,costless, with 2-3 hours laybour.
GOOD LUCK
GUS
Any suggestion,comments,... are wellcome.-
Tobiask (05-14-2019)
Old 05-26-2009, 01:57 AM
gusvlachos's Avatar
Thumbs up
[quote=gusvlachos;3534191]
Link for Diagramm: http://i594.photobucket.com/albums/t...TPSINSERTS.jpg
...,just pay!
SYMPTOMS:
ERROR CODES:
TOOLS:
PROCEDURE:
1) Remove keys
WARNING:
TPS INFORMATION:
TPS VOLTAGE TEST:
TPS REPAIRING:
THE TRICK:
next final step.
GOOD LUCK
GUS
Old 05-27-2009, 05:44 PM
Good post. Nice giving yourself a thumbs up.
Old 05-27-2009, 06:26 PM
Super Moderator
+10000000000000000000
Old 05-28-2009, 02:11 AM
gusvlachos's Avatar
Thanks,"C 23O SPORT COUPE".
Thanks,Glyn.
Old 06-16-2009, 02:12 PM
SchwarzesAMG's Avatar
W209 CLK '06
Well thats a good mechanic, finding the problem by using right tools and skeptic
And thats a crazy dude fixing this problem that way
Old 06-16-2009, 04:47 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
I'm inclined to give a guy quite a bit of leeway when he comes in, brings good tech/knowledge and shares it.
Would rather read posts like this than....
Post a pic of xxx body kit blah blah.
Ed
Old 06-17-2009, 04:03 AM
gusvlachos's Avatar
Don't bother your self Ed ,this country has a lot like him.
Gus
Old 07-08-2010, 05:07 PM
danev6972's Avatar
2003 C240
Happened to me earlier today too. Came out of Applebees and was sitting at a red light. The car just revved up and didn't go...I put it in Neutral and back to Drive and the car accelerated again. TPS problem also right? Would a MAF sensor cleaning help?
Battery and CPS is fairly new.
Going to do the throttle reset now.
Mileage 77546 will do a tranny flush soon.
Hopefully it's just a fluke and won't happen again god knows I can't afford any car repair at the moment..my dad's medical bills are killing me!!!!
Old 07-13-2010, 05:46 PM
gusvlachos's Avatar
Look's like a TPS failure in progress.
If it happen again let me know.
I'll guide you to resolve this problem costless.
Gus
Old 05-03-2011, 08:17 PM
danev6972's Avatar
2003 C240
Gus
Happened again today Gus...10 months after the first incident. Almost "redlined" the RPM. I think i'll just go ahead & buy the whole assembly $181 @ rmeuropean. This should be a simple install right?
http://www.rmeuropean.com/Part-Numbe..._5C1313F8.aspx
Do I wait until I get an error code before replacing the pedal or is it advisable to do it now?
FYI: MAF & throttle body have been cleaned. Battery is new.
Old 05-11-2011, 07:01 AM
gusvlachos's Avatar
Sorry for the delay,
Replace it now, it is easy.
Follow the described proceedure
Gus
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: W203.045 TPS FAILURE?
