c240 door rust? from the driver inside.
After 36 hour rain, having the car outside - I was visiting friends, relatives, and work, I noticed this door rust!
What should I do? It appears to be from the rubber? Or on the joint between the rubber? It would appear the problem came from the
It seems I have several option. Should I seal the seams with anti rust paint spray (the point where the rubber meets the metal)?
Or
Have it professionally done. Take the rubber out, etc.
Or
Any other suggestion?
http://timcodes.zenfolio.com/img/v12/p995303602-4.jpg
Here is a higher resolution picture:
http://timcodes.zenfolio.com/img/v12/p995303602-6.jpg
Thanks!
Rusted metal - even perforation - clean and coat with POR-15 prior to any bodywork and paint.
Keeping rust out of door jams and areas that can't easily be reached (proactive/preventative) - Waxoyl - is a penetrating coating that keeps rust away. Once applied, it has a slightly greasy feel much like fresh Carnauba wax in the can. Keeps rust from starting. It has been used by automotive rust proofing companies for years.
From your pic, it is hard to tell whether you have a real issue or not. Are you able to pull the rubber away and see what is causing the orange film?
Thanks for the feedback, I have no idea where to get these items, but I will try.
However, I do have some rust-converter, and a "white" anti paint rust from Canadian tire.
I can't peel the rubber away, I think it's glued into the door at the bottom of the driver's side. Should I forcibly peel the rubber?
Looks like Waxoyl now comes in aerosol cans - http://www.roversnorth.com/store/p-5...l-aerosol.aspx
Hopefully you have very little to be concerned about - sometimes a pin-sized dot of rust can cause the stain that you see. That can easily be remedied by cleaning with 3M adhesive remover and touching up with Rustoleum. I would not use the rust converter - I have never had success with any of them. Good luck - it does look very minor from the pics.
