NegroC230's Requested Info
Old Apr 8, 2010 | 03:51 AM
W203E35's Avatar
2006 C350 Sport 6MT
I think I get why you were asking the question. I think they all use the same manifold.
The 230 and 350 (w203) have the same part number for the manifold
The 300 and 350 (w204) have the same part number for the manifold.
I have attached how to change manifold on the w203 and w204. Also I have attached all part numbers (230, 350, 300, 350)
W203 C230
W203 C350
W204 C300
W204 C350
Hope all this info helps
Old Apr 8, 2010 | 12:00 PM
NegroC230's Avatar
08 ML CDI
again thanks a million. helps alot. I ordered a set of headers, after visually matching the exhaust bolts and flange placements.with the diagram you provided i wanted to see if there were any major differences between w204 and w203 M272 powerplants, but i doubt there are any and i dont see any. ill keep you posted when the they come in and tell you how it worked out. thank you again for your help.
Old Apr 8, 2010 | 02:26 PM
nrg_mike's Avatar
2005 C320 Sport, 2010 C300 Sport
Vote for sticky!
Old May 27, 2010 | 10:55 PM
W203E35's Avatar
2006 C350 Sport 6MT
This is all I could find for the o2 sensor. I couldn't find a wiring diagram.
Hope it still helps.
Old May 28, 2010 | 12:49 PM
ontmiss's Avatar
2007 C280 4matic Avantgarde
Here are some diagrams if it can help
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
