Annoying SOS Malfunction
I did NOT renew my teleaid subscription, but if that was the cause of my problems, I would expect the SOS malfunction to be on constantly.
I have 4500 miles till my next service and hope to have determined a pattern by then.
Thanks - John
Here's an "interesting" weather-related problem that we notice w/ my wife's Regal GS: When snow blocks part of the cowl vent, her climate control external readout goes bonkers. It starts rising way past the outside temp, like up to 80 degrees! There must be a design flaw where air doesn't circulate properly to some external sensor when it's partially blocked. They replaced the main control unit once but we still notice the problem.
Further diagnostics showed the connectors on the control module were not fully seated, so they popped all connectors off all the components in the fiber loop and reseated them. This took about 3 hours total.
Yours is a pretty early car, as I recall. If they haven't installed/run/whatever they do to the new software, you might want to see if they will do it for you.
Thanks for the replies - John
